IBM Thinkpad 500 and 510
Hi Everyone
A couple of machines here you don't see many of. The 500 and the 510:
More pics and comparisons here:
https://imgur.com/a/hvlnBQi
I previously stripped down the 510 for two reasons - to find out if there was any damage inside from leaking caps or batteries and to repair the vinegar syndrome screen. It was a bit of a nightmare because I don't believe it's built by IBM - it's got a Phoenix BIOS and a Lexmark sticker inside (not on the keyboard). Also the plastic which has RF shielding built-in is becoming very brittle.
For anyone feeling the need to take one of these apart, it feels terrible when it's unknown but simply put - you take all the screws out of the base and then with the machine the right way up, you kinda creak the front plastic forward to lift out the keyboard which has big plastic tabs at the back - you then lever it up from the front.
Then the base comes off completely by using a spudger either side to seperate the base from everything else.
Upside down with the base removed, you face a motherboard which simply lifts off from the DC daughterboard which is built into the keyboard bezel. The only electrolytic caps on the 510 were on the DC/DC board:
This is connected to the mainboard via that 24 pin connector, but you're more like attaching the motherboard to the tiny DC board than the other way around.
The hinges for the lid do not have great foundations and are all very weak now due to the brittle plastic. They crack and break and I suspect in another decade or two all 500/510 machines will have broken lids.
The lid itself is one of those ones where the top - the bit you're looking at with the laptop closed, lifts off the display which remains hinged in place. You undo two screws on the LCD bezel and then the whole back pushes back at the base and then slides up and off 5 tabs at the top which hold it onto the LCD bezel. Again the plastic is brittle.
Here are the tabs at the top of the lid, which need to be slid upwards to hinge the lid off:
More pics of the disassembled 510 here:
https://imgur.com/a/DANuQOM
My 500 is in much nicer natural condition because it's not an asian machine.
I know these teardowns get a *lot* of responses on here, so excited to hear all the amazing comments.
Re: IBM Thinkpad 500 and 510
Indeed, plastics look brittle.
The inside of the plastics is painted similarly to Acer's.
Is the battery on the motherboard permanently fixed?
390X,570E,600E,iSeries1200,A21m,A30P,A31,A31P,G40,R30,R31,R32,R40,R40e,R50,R50e,R51,R51e,R52,R60,R400,
T20,T21,T22,T23,T30,T40,T41,T41P,T42,T43,T60,T400,X24,X30
hey, I like the teardowns. you'd probably get more replies and conversation going on a vintage tech specific forum though. not sure how large the vintage audience is here, but it seems quite small.
i'll bet a good amount of epoxy could keep one of these together in one piece. might look real ugly from the outside, but if it works, it works. better in my view than letting it fall apart.
seems all the early IBMs have garbage built hinges.
Your average ThinkPad collector.
Owns: T480, Yoga S1, modded T430, T61p (15.4"-GMA-WUXGA), R60e, T43 14" SXGA+, G40, T30 SXGA+, T23, A22p, T21, i1260, 600X, 385XD, 560, PS/Note 425
From memory, the 500 and 510 were IBM Raleigh / RTP designed and built. Should have serial numbers starting with 23. Same team that designed these did the 701.
235, 240, 350, 360, 380, 500, 535, 560, 570, 600, 700, 701, 720, 750, 750P, 755, 760, 770, 820, N33sx, PC110, T20, T30, T40, T60, T420, T460, W520, X20, X30, X40, X200, X300, X1 Carbon Gen 1
Dan's IBM PalmTop PC110 pages
Dan's ThinkPad 730T pages
It's good to know it's not a horrible imposter. I felt torn that I need to teardown the 500 and recap the DC board before it commits suicide but I just couldn't bring myself to do it. Incase something else breaks.
IBM were generally very explicit on the sticker underneath: either 'Manufactured by IBM' or 'Manufactured for IBM'.
I opened up an old wedge-shaped PS/2 mouse recently to clean it, and was amused to find a Logitech board inside. I've just pulled it off the shelf and it does indeed say "Manufactured for IBM" but confusingly has a 23- plant code, albeit a bodge as the plant code is printed as part of the label, the serial digits have been overprinted. I suspect in this instance the innards were supplied by Logitech to Raleigh, and this was assembled there into the plastic mouse body, cable added, IBM sticker applied, and then packed into an IBM box
Oh how the mighty had fallen...amused to find a Logitech board inside.
Well it still works!
I have had a lot of respect for Logitech devices over the years. Like anyone, their budget stuff can be junk, but they have been consistently good on mice, particularly at that time. Indeed I have Logitech MX master 3 mice for all my main desktops, very nice bits of kit, worthy of sitting alongside the Model M keyboards! Also the c920 webcam in early revisions did MP4 encoding in the camera, so would output a reliable high quality video stream over USB2 to an older laptop that might otherwise struggle to itself encode a raw video stream. When they invest in a product it shows
It doesn't matter who made these machines, they are very interesting due to their age.
I didn't even have a chance to see these models.
IBM Thinkpad 535X Teardown and Repair
by solidpro » Mon Feb 19, 2024 5:13 pm » in ThinkPad Legacy Hardware - 2 Replies
- 539 Views
Last post by solidpro
Sun Feb 25, 2024 3:33 pm
Classic ThinkPads installed in IBM System/390 and zSeries mainframes
by ThinkDan » Mon Nov 27, 2023 4:39 pm » in ThinkPad Legacy Hardware - 13 Replies
- 4647 Views
Last post by ThinkDan
Fri Feb 02, 2024 4:18 am
[FA][UK & Global] various IBM Space Saver and TrackPoint keyboards [WARNING: PICS]
by ThinkDan » Sun Mar 31, 2024 4:33 pm » in Marketplace - Forum Members only - 2 Replies
- 354 Views
Tue Apr 02, 2024 3:37 am
Need to repair IBM USB ThinkPad keyboard
by ThinkPad560X » Sun Dec 03, 2023 1:01 am » in Off-Topic Stuff - 0 Replies
- 1861 Views
Last post by ThinkPad560X
Users browsing this forum: Bing [Bot] and 18 guests
