I'm just refurbishing some Helix 2nd, initially to use my spares. After achieving proper installation of Windows 11, I have started to work on a pair of these.
The Helix 2nd 20ch 20cg (M-5<Y71/8GB-Variante) is a still fine machine and if You do not bother to install a heavy workload of software, it stays quick and swift.
After replacing bios-batteries, system-batteries and keyboard batteries, the systems are back and fine again ... I cleaned them out & after installed a M.2 Sata SSD (512GB). Windows 11 is installed, activated, all system go and fine.
But one: Sierra 7345 WWAN
Sierra 7345 WWAN does install properly (it seems) and seems working properly (Gerätemanager / Systems Manager), but Lenovo new diagnosis-tool does tell me,
it does not see a SIM-Card (so it does not test Sierra). WIndows 10 & Windows 11 the like.
Any help or advice?
(I have seen some advice, I do hesitate to follow (using some software for installation, change parts of it to update the firmware (!) of those. cards) and I consider uninstalling all sierra software & updates, than restart from scratch. But that probably would not do the trick?!)
Help and advice would be welcome!!
TP Helix 2nd: how to have Sierra 7345 WWAN-module work?!
- thinkpads.com customer
-friedrich-eugen-
started with IBM-XT & AST-Ascentia (910N) in the 90ties, relying on Thinkpads (770X, A31P, T60-61P Frankenp.) until 2017,
still using TP W530 FHD (i7 Nvida 2GB, 32GB, 500GB & 2TB SSD), X230T (i7 16GB/ 1TB), TP Yoga X390 (i7 16GB 2TB)
Windows 10 & Windows 11 Pro
P1 5th gen - Swapping keyboard with WWan antenna for keyboard without Wwan. Possible?
by Phidelio » Mon Jan 15, 2024 9:21 am » in ThinkPad P1/P40/P50/P70 and later Series - 1 Replies
- 2407 Views
Last post by H-Atkinson
Fri Jan 19, 2024 2:56 pm
I have a Lenovo Legion - I know it's not a thinkpad, but I have a question
by whoknows88 » Mon Nov 27, 2023 7:48 pm » in GENERAL ThinkPad News/Comments & Questions - 5 Replies
- 3446 Views
Last post by whoknows88
Wed Nov 29, 2023 4:20 am
W530 - WiFi module upgrade for 802.11AC / AX ?
by ac427 » Mon Mar 18, 2024 6:58 am » in ThinkPad W530/W540/W541/W550 Series - 8 Replies
- 979 Views
Last post by mstar
Sun May 05, 2024 5:05 pm
- 0 Replies
- 4518 Views
Last post by bjain29
Mon Nov 20, 2023 9:28 am
