BIOS with whitelist disabled?
Sorry if this is a FAQ, but:
I got a T440S with the realtek wifi card, which isn't working out for me, and Lenovo doesn't have any of the Intel cards in stock (0.o), so I literally cannot pay them to fix this except by *returning the whole laptop*. ;_;
Before I knew about the whitelist, I got a compatible Intel card from newegg, but it doesn't work.
Can anyone help me out with a de-whitelisted BIOS, or instructions on how to make one, or anything? The official downloads are at V in case that helps.
Re: BIOS with whitelist disabled?
It is impossible to use a mod-BIOS on any ThinkPad since 2012, since the newer UEFI-BIOS versions are "secured" and encrypted, and impossible to mod.
You will have to return the machine or buy an genuine Lenovo part.
They have started using Insyde BIOS instead of the more popular Phoenix BIOS versions.
Register on this website and put in a request for a modded BIOS: http://forums.mydigitallife.info/thread ... y-Thinkpad
They are one of the best people to ask, and may be able to help you!
;_;Ibthink wrote:It is impossible to use a mod-BIOS on any ThinkPad since 2012, since the newer UEFI-BIOS versions are "secured" and encrypted, and impossible to mod.
I would be happy to buy a genuine Lenovo part but they won't let me. ;_; (they're out of stock)
Thanks for the info.
Puppy
It very likely won't change anything, I've just found (and signed) this http://www.change.org/petitions/lenovo- ... f-the-biosIbthink wrote:It is impossible to use a mod-BIOS on any ThinkPad since 2012, since the newer UEFI-BIOS versions are "secured" and encrypted, and impossible to mod.
ThinkPad (1992 - 2012): R51, X31, X220
Huawei MateBook 13
Huawei MateBook 13
Nothing is impossible...
Check the info about an X230, which has the same type of BIOS:
http://forums.mydigitallife.info/thread ... nkpad-X230
Check that website (and/or Google) for similar models like T430, T440, X230, X240 etc.
What about just buying the Lenovo Intel card on eBay? I bought those for all my older Thinkpads no issues. Just make sure it is for Lenovo and not the generic one such as this one:
http://www.ebay.com/itm/Wireless-AC-726 ... 51ba896c16
Easy peasy?
Easy peasy?
you can join http://www.bios-mods.com/ and asked for removing whitelist BIOS there.
however, AFAIK there's no software way YET to write modified BIOS for >= T430 or >= X230.
you should done it using hardware flash programmer with the help of SOIC clip or replacing the chip.
i've personally do the first option (SOIC clip) with success.
this is my discussion during removing whitelist there:
http://www.bios-mods.com/forum/Thread-R ... programmer
other guy said he had no luck with such clip, so he remove the chip and replace with a new one with modified bios.
(http://www.bios-mods.com/forum/Thread-T ... ware-Flash)
this link might be in consideration when choosing flash programmer.
http://www.bios-mods.com/forum/Thread-L ... 2#pid72242
Other easier method is getting the wifi card that is in the whitelist.
you can use andy phoenix tool to extract the bios, and check the module having the listed card using hex editor.
then go buy the card in ebay.
T14 Gen 1 AMD - problems with wwan card: whitelist?
by piripuz » Mon Nov 17, 2025 4:42 am » in Thinkpad T14/T15/T16 - 4 Replies
- 10512 Views
Last post by piripuz
Wed Nov 19, 2025 5:56 am
P14S Gen 6 AMD - WWAN Whitelist?
by H-Atkinson » Sat Feb 21, 2026 11:41 am » in ThinkPad P1/P14/P15/P16/P40/P50/P70 and later Series - 3 Replies
- 3511 Views
Tue Mar 10, 2026 5:27 am
T440P; help me with removing whitelist & unlocking advanced menu
by LUC1FER » Sun Mar 15, 2026 11:27 pm » in ThinkPad T430-T495 / T530-T590 Series - 1 Replies
- 1177 Views
Mon Mar 16, 2026 1:14 am
- 2 Replies
- 7663 Views
Last post by LayaVulpes
Tue Oct 21, 2025 12:12 pm
Users browsing this forum: No registered users and 69 guests
