Yes, I know. But this one is not for me, and the guy is struggling to get his on European market.
15", Retina display. Show me what you have (please?).
LF: MacBook Pro 2014-2015
(stable under reduction)
Re: LF: MacBook Pro 2014-2015
Wait, are you specifically looking for a 2014~2015 15.4" MacBook Pro with a dedicated graphics chip? Or, are you looking for an integrated graphics chip model?
Some models were also equipped with different processors, which may be important to you.
If you are looking at the 2014 15.4" MacBook Pro line-up with the integrated graphics chip (Iris Pro 5200), there are only three processors that were available with that configuration (Core i7-4770HQ, Core i7-4870HQ, Core i7-4980HQ). The dedicated graphics chip model (GeForce GT 750M), had only two processors that were available (Core i7-4870HQ, Core i7-4980HQ).
The 2015 15.4" MacBook Pro line-up with the integrated graphics chip (Iris Pro 5200), had the same processors that were offered with the 2014 15.4" MacBook Pro integrated graphics line-up. The same goes for the dedicated graphics chip model, although it was equipped with a different graphics chip (Radeon R9 M370X).
It might be beneficial for you to specify which configuration that you would prefer the most, at the very least.
The guys budget is what makes the difference.
Starting from most signifficant:
1. Retina display; 15,4"
2. Good shape
3. Good battery life
4. Dedicated GPU
All the other specs are less signifficant, all options are welcome, however.
2. Good shape
4. Dedicated GPU
T580 Compared to Classic Thinkpads and Macbook Pro
by MisterB » Fri Mar 15, 2024 12:51 pm » in ThinkPad T430-T490 / T530-T590 Series - 0 Replies
- 241 Views
Last post by MisterB
T14 Gen3 (Intel) and SSD Samsung 990 Pro 4TB
by Jan_888 » Tue Feb 13, 2024 5:54 pm » in Thinkpad T14/T15/T16 - 1 Replies
- 744 Views
Last post by ZaZ
Thu Feb 15, 2024 7:56 pm
