I'm looking for a couple Genuine Lenovo T61 era serial 2nd HDD adapters, the ones that take a SATA drive and have the tab that prevents them from going into a T40 era system. The tab can be filed off but it needs to be a real Lenovo one. The two FRUs that I know of are 45J7902 and 26R9246/7.
The aftermarket ones I have are being a pain (PITA). Maybe I'll use those in T40 systems.
WTB: Genuine Lenovo T61 era serial 2nd HDD adapter FRU 45J7902 or 26R9246
600 600X
760LD FUBARd
T41 T42 T43
T500 2
T530 W530
760LD FUBARd
T41 T42 T43
T500 2
T530 W530
Re: WTB: Genuine Lenovo T61 era serial 2nd HDD adapter FRU 45J7902 or 26R9246
I found a couple in my "stash". I need to sort this stuff out better. But I'm still looking for reasonably two priced ones.
600 600X
760LD FUBARd
T41 T42 T43
T500 2
T530 W530
760LD FUBARd
T41 T42 T43
T500 2
T530 W530
Just being curious - do they adapt SATA to PATA?
X220, 2 *T520
These will take a SATA drive and they fit in the T60 / T61, and some other 60/61 series (Z, X, etc). they have the tab that prevents them from being fitted into the T40 series.
These adapters convert the SATA to PATA for the drives in the ultrabay and I do believe this is done Inside the HDD adapter tray, because if you cut the tab off they will fit in a T40 series and do work, and the T40 series cannot take a SATA drive without physical mods as described elsewhere in this forum.
600 600X
760LD FUBARd
T41 T42 T43
T500 2
T530 W530
760LD FUBARd
T41 T42 T43
T500 2
T530 W530
Need a Thinkpad recommendation - 2009 Era
by KwikFab » Sat Dec 16, 2023 1:09 am » in Thinkpad - General HARDWARE/SOFTWARE questions - 11 Replies
- 3405 Views
Last post by KwikFab
Wed Dec 20, 2023 5:48 pm
ThinkPad from the 755 era with transparent screen
by Int_31h » Mon Feb 26, 2024 9:03 am » in ThinkPad Legacy Hardware - 17 Replies
- 1016 Views
Last post by BillMorrow
Tue Mar 19, 2024 12:51 pm
HELP! My X230 decided not to charge my non-genuine battery.
by canonmasta » Fri Dec 08, 2023 5:31 pm » in ThinkPad X230-X280 / X390 Series - 1 Replies
- 10802 Views
Sat Dec 09, 2023 12:07 am
- 0 Replies
- 4305 Views
Last post by bjain29
Mon Nov 20, 2023 9:28 am
