FREE: IBM ThinkPad T30 (TYPE 2366-61U)
cds.helpdesk
#1 Post by cds.helpdesk » Thu Jun 17, 2021 5:09 pm
20210613 REPOSTING since no response from individual who replied originally.
No HDD, no HDD cover.
Includes IBM AC Adapter and battery.
I believe there may be a bad SODIMM slot but i did not test completely.
This laptop is in OK condition and still works.
FREE FOR LOCAL PICKUP ONLY IN MA, just north of Boston, MA.
Please be patient with my responses as they may not be timely....
I will update the post as soon as possible when claimed/gone.
PM me with phone number and/or email.
lubuntu@lubuntu:~$ sudo inxi -Fxxx -m
System:    Host: lubuntu Kernel: 4.10.0-28-generic i686 (32 bit gcc: 5.4.0)
           Desktop: LXDE (Openbox 3.6.1) info: lxpanel dm: lightdm Distro: Ubuntu 16.04 xenial
Machine:   System: IBM (portable) product: 236661U serial: 78BTH20  Chassis: type: 10
           Mobo: IBM model: 236661U serial: J1MJU2562CD Bios: IBM v: 1IET26WW (1.00c) date: 04/12/2002
CPU:       Single core Intel Pentium 4 Mobile (-UP-) cache: 512 KB
           flags: (pae sse sse2) bmips: 2392 speed/min/max: 1200/1200/1600 MHz
Memory:    Array-1 capacity: 1 GB (check) devices: 2 EC: None max module size: 512 MB
           Device-1: DIMM 1 size: 512 MB (Double-bank) speed: N/A type: SDRAM (Synchronous)
           bus width: 64 bits manufacturer: N/A part: N/A serial: N/A
           Device-2: DIMM 2 size: No Module Installed type: SDRAM (Synchronous)
Graphics:  Card: Advanced Micro Devices [AMD/ATI] RV200/M7 [Mobility Radeon 7500]
           bus-ID: 01:00.0 chip-ID: 1002:4c57
           Display Server: X.org 1.19.3 drivers: ati,radeon (unloaded: fbdev,vesa)
           tty size: 125x46 Advanced Data: N/A for root
Audio:     Card Intel 82801CA/CAM AC'97 Audio Controller
           driver: snd_intel8x0 ports: 1c00 18c0 bus-ID: 00:1f.5 chip-ID: 8086:2485
           Sound: Advanced Linux Sound Architecture v: k4.10.0-28-generic
Network:   Card: Intel 82801CAM (ICH3) PRO/100 VE (LOM) Ethernet Controller
           driver: e100 v: 3.5.24-k2-NAPI port: 8000 bus-ID: 02:08.0 chip-ID: 8086:1031
           IF: enp2s8 state: up speed: 100 Mbps duplex: full mac: 00:09:6b:10:16:76
Drives:    HDD Total Size: 1.0GB (Used Error!)
           ID-1: USB /dev/sda model: USB_DISK size: 1.0GB serial: DISK-0:0 temp: 0C
Partition: ID-1: swap-1 size: 0.26GB used: 0.26GB (100%) fs: swap dev: /dev/zram0
RAID:      System: supported: N/A
           No RAID devices: /proc/mdstat, md_mod kernel module present
           Unused Devices: none
Sensors:   System Temperatures: cpu: 46.0C mobo: 45.0C
           Fan Speeds (in rpm): cpu: 3721
Info:      Processes: 128 Uptime: 38 min Memory: 388.5/491.6MB Init: systemd v: 229 runlevel: 5 Gcc sys: N/A
           Client: Shell (sudo running in bash) inxi: 2.2.35
lubuntu@lubuntu:~$
evening_hunger
Re: FREE: IBM ThinkPad T30 (TYPE 2366-61U)
#2 Post by evening_hunger » Sat Sep 11, 2021 9:02 am
the second sodimm slot has like a 90% failure rate with time, mine is broken aswell :)
did you give the machine away finally?
T14amdR7-4750U/32GB/500gb.ssd/debian_testing (main driver)
X320/i7-2620M/8GB/256gb.ssd/FHD13.3''IPS/debian_testing (ex-main driver)
T30Pentium-M 4 1.8Ghz 512MB RAM - under restoration
X230/i5/8GB/500gb.hdd+256gb.m2ssd/IPS/debian_stable+win7
755CE, 486DX, approx 28MB RAM (Win95 JP)
BillMorrow
*Senior* Admin
*Senior* Admin
#3 Post by BillMorrow » Mon Sep 13, 2021 12:43 am
those T30 thinkpads, early ones at least, had bad memory slots..
a T30 is also the notebook of choice for the mercedes benz star diagnostic system so a T30 DOES have some value..
Sysop - forum.thinkpads.com
~~~Mark Twain~~~
evening_hunger
#4 Post by evening_hunger » Mon Sep 13, 2021 8:17 am
Oh but I have one thank you very much. I even learned about that affection of the automotive guys to it, since my own T30 has had been used before for the BMW diagnostics. I suppose it's the parallel port they're using. Mine had it enabled in the BIOS and set to some specific IRQ...
Users browsing this forum: No registered users and 63 guests
