Thinkpad T41 + docking station + 4 9 cell batteries = $40
h2
#1 Post by h2 » Tue Jun 14, 2022 4:51 pm
I am clearing out some of older stuff, and thought maybe someone here would want this.
It's as is, all in one, my goal is just get rid of it, ideally to a good home.
Known warts. 1 of the usb plugs is dead I think. The audio plug is dead, or was last I checked. The 6 cell battery is low state, about 14% of battery life remaining. Surprisingly, it has not lost anymore since I last tested it in 2016. The CMOS battery may be dead, I'm not sure, it had lost the date data.
Comes with: 6 cell battery, 4 9 cell batteries, 1 IBM thinkpad docking station, 2 IBM power supplies, and the T41. If I can find it, also another cpu, I had 'upgraded' the cpu to a 2000 mhz one, but that was a bad idea I found, the thinkpad had trouble keeping that cool.
2 GiB ram, 80 GiB seagate hdd, that may have errors, I was getting errors running inxi on it. Other than warts, machine is in decent shape, docking station works, and the 4 9 cells are marked with their last states of charge when I packed them away.
Asking a token fee of $40 plus $15 shipping, assuming I can cram all this into a flatrate usps priority mail box.
I have some PCMCIA cards too if you tell me what you want, I'll just toss those in as freebie extras. And maybe a spinning 2.5" disk, but those take a while to wipe.
If this is of use to anyone, let me know, figured I'd stop by here first.
Drive will be wiped when it's shipped.
I was going to boot AntiX on this, but I don't think this one supports USB boot, so i had to use an old install CD, so some data is missing. On onother OS, I checked the battery state of charge, and it was 14% capacity remaining. The 9 cells I think have more.
System:    Kernel: 2.6.22.3-rc1-slh-smp-2 arch: i686 bits: 32 compiler: gcc v: 4.1.3
             parameters: lang=us boot=fll quiet vga=791
           Console: tty 1 DM: KDM Distro: sidux 2007-03.1 - Γαια - kde-lite - (200708151418)
             base: Debian lenny/sid
Machine:   Message: No machine data: try newer kernel. Is dmidecode installed? Try -M --dmidecode.
Memory:    RAM: total: 1.98 GiB used: 71.3 MiB (3.5%)
           RAM Report: permissions: Unable to run dmidecode. Root privileges required.
PCI Slots: Permissions: Unable to run dmidecode. Root privileges required.
CPU:       Info: model: Intel Pentium M bits: 32 type: UP arch: M Dothan built: 2003-05 process: Intel 90nm family: 6
             model-id: 0xD (13) stepping: 6 microcode: N/A
           Topology: cpus: 1x cores: 1 smt: N/A cache: 2 MiB note: check
           Speed (MHz): 2000 min/max: 600/2000 scaling: driver: acpi-cpufreq governor: ondemand core: 1: 2000
             bogomips: 3988
           Flags: acpi clflush cmov cx8 de dts est fpu fxsr mca mce mmx msr mtrr pat pbe pge pse sep ss sse sse2 tm
             tm2 tsc up vme
           Vulnerabilities: No CPU vulnerability/bugs data available.
Graphics:  Device-1: ATI Radeon Mobility M7 LW [Radeon 7500] vendor: IBM driver: N/A arch: Rage 7 code: R200
             process: TSMC 150nm built: 2001-06 bus-ID: 01:00.0 chip-ID: 1002:4c57 class-ID: 0300
           Display: server: X.org v: 1.3.0 driver: X: loaded: radeon gpu: N/A tty: 80x24
           Message: GL data unavailable in console. Try -G --display
Audio:     Device-1: Intel 82801DB/DBL/DBM AC97 Audio vendor: IBM driver: N/A bus-ID: 00:1f.5 chip-ID: 8086:24c5
             class-ID: 0401
           Sound Server-1: ALSA v: UTC) running: yes
           Sound Server-2: OSS v: N/A running: yes
Network:   Device-1: Intel 82540EP Gigabit Ethernet vendor: IBM PRO/1000 MT driver: N/A port: 8000 bus-ID: 02:01.0
             chip-ID: 8086:101e class-ID: 0200
           IF: eth0 state: up speed: N/A duplex: N/A mac: <filter>
           Device-2: Intel PRO/Wireless 2200BG Network driver: N/A bus-ID: 02:02.0 chip-ID: 8086:4220 class-ID: 0280
           IF-ID-1: irda0 state: unknown speed: N/A duplex: N/A mac: <filter>
Bluetooth: Message: No bluetooth data found.
Thanks for looking.
