time keeps changing in bios
Hi - I've got a t-60 running xp and linux - everything works fine but the time kept jumping ahead 4 hours - so I went into the bios and set the time to where it should be -that worked for a short time - so then I set the bios time to 4 hours earlier than it should be and after awhile it reset itself to 4 hours ahead of what it should be - no matter what I do it always goes back to 4 hours ahead - I have xp and linux set to the correct time zone. ???
Re: time keeps changing in bios
A near-dead CMOS battery comes to mind.
Available on e.g. eBay, check for: lenovo t60 cmos
All TP's use the same CMOS battery. If you have another machine laying around, that is another possibility.
Windows assumes that the system time is local time, while Linux assumes that system time is GMT, and adds the time zone offset. I'm pretty sure this is the cause.
You ahould be able to set either Linux or XP to not change the CMOS settings. Linux will likely be tge easier to change but IDK.
There's a registry key in Windows 7 that forces it to accept system time as UTC. Unfortunately, Windows XP does not support this registry key.
Wrong Time in Windows 10/11 (-1h)
by canonmasta » Fri Dec 15, 2023 6:22 pm » in ThinkPad X230-X280 / X390 Series - 1 Replies
- 2714 Views
Sat Dec 16, 2023 1:29 am
I'm Back and This Time It's Personal
by ZaZ » Sun Dec 24, 2023 6:58 pm » in ThinkPad L430/L530 and later Series - 11 Replies
- 6307 Views
Wed Jan 17, 2024 1:48 pm
updating T480 bios without Windows (I use Linux)
by redglow » Fri Nov 03, 2023 3:15 am » in ThinkPad T430-T490 / T530-T590 Series - 25 Replies
- 30493 Views
Last post by redglow
Tue Nov 14, 2023 1:00 pm
t430 bios keyboard illumination tab has vanished
by Ray73 » Wed Nov 29, 2023 6:53 pm » in ThinkPad T430-T490 / T530-T590 Series - 5 Replies
- 2847 Views
Last post by TPFanatic
Thu Nov 30, 2023 4:23 pm
