So I ordered x270. Probably a little prematurely as I read a bunch of reviews about the following issues:
- poor IPS quality with bleeding
- keyboard flex
- overheating
It’s arriving this week, I will probably open it to see if any of the above are true in this particular unit. Otherwise I will return it.
So my question is...
Is there any new thinkpad out there that would meet the following requirements for me:
- screen without bleeding
- hinge that prevents screen wobble
- no flexing on the keyboard
- good Linux support
So far I looked at:
1) x270
- obviously has some of these issues
2) T470s
- better IPS screen
- screen wobble effect as per notebook check so completely out of the question
3) P51
- better IPS screen
- minimal screen bleeding
- no report of hinge to screen wobble
4) A series
- very few reviews still since it’s new but looks to be same as T series chassis with AMD processor.
5) L and E series are budget options so I didn’t consider them
I went to Apple Store, Microsoft Store and Best Buy to check out some other options out there.
6) Yoga 910
- sturdy hinge
- good screen
- poor Linux support
7) Alienware
- meets all criteria but looks more like a toy than laptop
- unknown Linux support
MacBook Air/Macbook
- loose hinge
9) MacBook Pro
- meets most criteria (good hinge, good screen)
10) XPS 13
- meets all criteria but is know for horrendous hardware quality with multiple complaints of units breaking down not working out of the box
Any high quality new thinkpads out there?
Buying used ThinkPads in New Zealand
by m137 » Tue Nov 14, 2023 5:07 pm » in Marketplace - Forum Members only - 13 Replies
- 2813 Views
Last post by BillMorrow
Sat Nov 18, 2023 8:05 pm
Classic ThinkPads installed in IBM System/390 and zSeries mainframes
by ThinkDan » Mon Nov 27, 2023 4:39 pm » in ThinkPad Legacy Hardware - 13 Replies
- 4447 Views
Last post by ThinkDan
Fri Feb 02, 2024 4:18 am
small bug when swapping Thinkpads in advance Dock station 2503
by n2ri » Sat Jan 27, 2024 3:57 am » in ThinkPad W500/W510/W520 and W700/W701 Series - 1 Replies
- 1018 Views
Last post by mikemex
Tue Feb 13, 2024 2:54 am
T580 Compared to Classic Thinkpads and Macbook Pro
by MisterB » Fri Mar 15, 2024 12:51 pm » in ThinkPad T430-T490 / T530-T590 Series - 0 Replies
- 240 Views
Last post by MisterB
