Best External Keyboard
What are the best (Lenovo) external keybouards, in terms of pointing stick and typing?
Is USB better than Bluetooth in terms of speed and reliability?
Re: Best External Keyboard
From what I hear, the Bluetooth versions had annoying issues regarding input lag.
I'll stay with my two Model M's.
A31p P-IV 2Ghz, 2MB, 2653-R6U
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
T16 i7 1260P 21BV000SUS
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
The Model M looks great, but it's only available used, at $150!
So I'm looking for the best contemporary Lenovo USB keyboards.
Thanks.
Thanks.
If you decide you might want something old, something new, something white, something (big BLUE):
I have an original, brand-new genuine IBM KB-7993 keyboard, P/N: 12J5557, FRU: 12J5558 from 1998.
Looks like this: https://img-arch.pconline.com.cn/images ... 713490.jpg
Mine is in the original box, complete with a removable palmrest.
Keyboard has US-layout.
It has a PS/2 connector, but with a PS/2-to-USB adapter you can also plug it into any USB-port.
Could be yours for $40 shipped.
Do you know who made the keyboard for IBM made in that year?
Does the PS\2 convert to USB 2.0?
Thanks for the rhyme. You're in a good mood today.
It only says: Made in Thailand, so I assume NMB.
The keyboard's PS/2 converts to USB2.0.
RBS with my lunch always works well for me!
Where's the edit button?
So forgive the new post.
I checked on Amazon, looked at some PS/2 to USB convertors, and ran into a little bump.
Besides writing I play the occasional game, and am adept with the pointing stick. One reviewer, who wants it for the exact same purpose, says the adapter is great for typing, but bad for gaming. This prompted this response from the vendor"
https://www.amazon.com/Perixx-PERIPRO-4 ... FISON1N5C0
"...As PERIPRO-401 is only a converting cable without functions of processing data. It can support normal data transmitting from USB to PS2 interface, however, if it's involving gaming or other complex programs which may consume more CPU calculation, it's about CPU performance and software support instead of the cable itself. Therefore we'd suggest checking your computer spec again to have a better performance. "
I want to use this on an HP 8740W. Is there a software workaround for this in Windows10?
Yes, eating cheers me up too.
You should always have a snack at hand, RBS.
Okay. Found the edit button.
In all the years on this forum, I never pondered the significance of your nom de plume. Your last answer makes it clear that you have RBS (black coffee) with your meal You're a coffee aficionado. As I'm a tea drinker it never occurred to me.
ROFL! Ever read my signature?
And what's my avatar holding?
As for adapters, I got one of these: https://www.ebay.com/itm/173145971112
If you buy my keyboard, I'll throw it in with it.
To answer both questions, no I never read your signature, nor really looked at your avatar.
There's a great story by Poe called "The Purloined Letter" where the same phenomenon of not seeing something right in front of you is depicted.
I'm going to be checking into the adapter/gaming issue and will get back to you. Out of curiosity, can you generate a receipt on Paypal that can be paid as a guest? That's how I usually pay on Payal, as I don't have an account.
UPDATE:
So I checked out your avatar, and I see that he's holding a nice glass of iced tea in his talons.
And I looked for your signature, something I never do, and see the reference to Guinness. I was traveling by bus in Ireland from Cork to Galway, and the driver pulled over ever so often in front of a pub, and everybody in the bus filed out and filled up. I had one glass of the real, McCoy (fresh and homegrown) on an empty stomach, and someone floated or swooned my way back into the bus. Much different than the bottled stuff I]ve had here,
I checked out the ebay link, and one poster explained the issue
https://www.ebay.com/itm/173145971112#rwid
Apr 26, 2016 Top critical review
Passive device
This is a passive device and will not work with some legacy keyboards. Such cases require a USB PS2 ADAPTER CABLE for KEYBOARD and MOUSE PS/2 that has an intermediate circuit to provide an electronic interface..."
So I may need to check out a different kind of adapter, with a controller inside.
What's confusing is that these adapter cords tend to have two male plugs on one side, and USB on the other. Does the keyboard have one or two PS2 sockets?
UPDATE:
Passive device
Pckeyboards.com AKA Unicomp has brand new model M's with or without a trackpoint or trackball for 100$
Doesn't seem to be a center scroll button on the Unicomps, which makes them HPs.
I've had two of the newer chiclet style bluetooth keyboards. I thought they were pretty good, though I only type 35WPM or less. My only issue them is when I added an external HD that was poorly shielded, it messed up the connection. Once I replaced that, it was smooth sailing.
The keyboard has no PS/2 sockets at all, it has one PS/2 plug.taichi wrote: ↑Mon Apr 23, 2018 5:04 pmI checked out the ebay link, and one poster explained the issue
Passive device
And those adapters do not have two male plugs either, they have two female PS/2 sockets and one USB male plug!
And just in case, I have such a KB/mouse-USB adapter with controller as well.
Be happy to throw that in instead.
I'd use one of those old IBM PS/2 keyboard if you have a PS/2 port or one of those PS/2 to USB adapter.
I currently have IBM wireless keyboard and mouse from like 2000, IBM multimedia keyboard from 2005, and one of those ThinkCentre keyboard from 2012.
The 2000 wireless keyboard has that kind of mechanical click to it with loud noise, while the latter ones feel like definitely membrane.
I feel like the quality gets compressed and it feels lighter as the year progresses, but good enough for what I use it for either way.
600 PII-266 416mb 40gb WXP
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10 (Sharp)
UXGA:
I'm just not sure that a rubber dome keyboard would be as good as a mechanical one for my purposes, which include some gaming,
If you are talking about the rubber dome keyboard made for ThinkPads during the late 90s to mid 2000s, they are more than good enough for gaming.
That said, I feel like the newer ones made by Lenovo can sometimes feel quite mushy and not that great in terms of gaming.
UXGA:
UXGA:
The Unicomp apparently really nailed the typing experience of the Model M (they bought the patents) but it doesn't have a pressure sensitive TrackPoint pointing stick, but a pointing "wand" that is a small movable stick which has a completely different, less intuitive feel. Unfoirtunately, nothing has the sold feeling of control like the TrackPoint. I need a TrackPoint.Pckeyboards.com AKA Unicomp has brand new model M's with or without a trackpoint or trackball for 100$
Not just the patents, but the tooling as well. In other words, they're using the actual machines that IBM/Lexmark used to make Model M's with.
I've read somewhere that the Trackpoint patent has expired. Hopefully Unicomp can take advantage of this.but it doesn't have a pressure sensitive TrackPoint pointing stick, but a pointing "wand" that is a small movable stick which has a completely different, less intuitive feel.
I'm aware of, but didn't mention the tooling, as I've read their web page, read reviews about their product, and spoken with their tech support. Apparently it isn't cost effective for them to add a TrackPoint.
The pointing stick on my Elitebook, and even the associated mouse buttons are so much more awkward than the TrackPoint. That's why I'm looking fir an external keyboard.
Is anyone using IBM model M for External keyboards?
For what I have right now, the most comfortable external keyboard is hands down my wireless SK-8088 keyboard. It is probably not near as good as Model M, but is still a lot clickier than just about any non-mechanical keyboard today. Too bad that the wireless receiver doesn't quite keep up well when typing very fast.
UXGA:
UXGA:
Turn your favorite laptop-keyboard into an external USB-keyboard: https://superuser.com/questions/184870/ ... 56#1004056
Yow! That's audacious, and beyond my technical abilities.RealBlackStuff wrote: ↑Wed May 02, 2018 10:43 amTurn your favorite laptop-keyboard into an external USB-keyboard: https://superuser.com/questions/184870/ ... 56#1004056
If I had those skills and inclinations i would use the keyboard from my old A21P.
According to that logic, My 755C ain't a Thinkpads and it sure as hell is, for the once and only time I dropped off the desk and I had a 15" Compaq on the floor below it and it fell and cracked the screen of the Compaq. For the 755C, well it was kicking and alive.ZaZ wrote: ↑Tue Apr 24, 2018 12:20 amDoesn't seem to be a center scroll button on the Unicomps, which makes them HPs.
Is this a Lenovo? I can't find it on Amazon. Also can it be plugged in, or is it only bluetooth?kfzhu1229 wrote: ↑Wed May 02, 2018 12:06 amIs anyone using IBM model M for External keyboards?
It's probably SK-8808.taichi wrote: ↑Sun May 06, 2018 11:27 amIs this a Lenovo? I can't find it on Amazon. Also can it be plugged in, or is it only bluetooth?kfzhu1229 wrote: ↑Wed May 02, 2018 12:06 amIs anyone using IBM model M for External keyboards?
Yes you are right, it was a typo. It is SK-8808.
It is a wireless mouse and keyboard combo set with one giant USB receiver and wireless keyboard + mouse, all of which (except the receiver) take AAA batteries.
Just as a note, if you are using rechargeable batteries, the response rates of them aren't very good due to the lower voltage. It is not abnormal for the keyboard to lose a character every 50 characters or so, especially when you type fast.
Definitely do not attempt to use them for response sensitive tasks such as FPS gaming. There is a USB wired equivalent with a slightly different model number if you want.
That said, the sound and the feel of this keyboard feels quite nice.
UXGA:
UXGA:
I have the PS/2 version, and my brother has the USB one. They're quite good TBH. Used/second hand ones are sold between 3 and 6 USD here, marketed as "heavy duty, for computer shop use".
Any idea what the model number of the USB one is? I would rather have USB than use a convertor. All of these are rubber dome, I imagine?axur-delmeria wrote: ↑Mon May 07, 2018 3:10 amI have the PS/2 version, and my brother has the USB one. They're quite good TBH. Used/second hand ones are sold between 3 and 6 USD here, marketed as "heavy duty, for computer shop use".
On a different note, is there a best source for the IBM convex (dome-shaped) rubber tips for the Trackpoint? Apparently, the tips on the HP pointing sticks can be swapped for those, improving sensitivity or "feel."
https://www.ebay.ca/itm/Vintage-IBM-Key ... SwwCharpn3
That is SK-8809, which looks like exactly the same as mine except with a wire running through and that mine, being battery powered 1999 wireless technology, has no LEDs whatsoever.
For mine SK-8808, I think it is rubber dome, but it doesn't feel like one with loud clicky sounds and good feedback and travel distance, and is also pretty comfortable to type on.
If you bought that one, please help me figure out what driver to use to enable all of those coloured hotkeys instead of only having the sleep button and e-mail button working.
UXGA:
UXGA:
P1 5th gen - Swapping keyboard with WWan antenna for keyboard without Wwan. Possible?
by Phidelio » Mon Jan 15, 2024 9:21 am » in ThinkPad P1/P40/P50/P70 and later Series - 1 Replies
- 2115 Views
Last post by H-Atkinson
Fri Jan 19, 2024 2:56 pm
X230 - what SSD will best fit in the WWAN slot?
by br1anstorm » Tue Nov 14, 2023 3:59 pm » in ThinkPad X230-X280 / X390 Series - 15 Replies
- 5769 Views
Last post by br1anstorm
Wed Nov 15, 2023 6:17 pm
What's the best way to remove paint from stock Thinkpad coolers?
by cultOfThinkpad » Sun Dec 10, 2023 6:52 am » in Thinkpad - General HARDWARE/SOFTWARE questions - 1 Replies
- 4397 Views
Sun Dec 10, 2023 12:55 pm
Recommendations: Best Sources for New Battery
by Commando303 » Sat Jan 06, 2024 8:51 pm » in ThinkPad W500/W510/W520 and W700/W701 Series - 1 Replies
- 1369 Views
Last post by mikemex
Sat Jan 06, 2024 11:27 pm
