Can't get Intel(R) PRO/Wireless 2200BG WIfi working on ThinkPad T43
jamesfx2
#1 Post by jamesfx2 » Mon Oct 02, 2017 5:08 pm
My Thinkpad T43 has a Intel(R) PRO/Wireless 2200BG card and I need to get it working in WIndows 7 32 bit... It works perfectly in Ubuntu 12.04 - can connect without issues.
But in WIndows 7, it can see a bunch of networks and I can try to connect to one and enter a password... but it won't connect. It just fails to connect each time. I figured it was a driver issue - I've tried the version that comes with WIndows 7, I've tried the Vista 32 bit version, I've fiddled with settings. But I think oother people have managed to get it working straight away.
kfzhu1229
Re: Can't get Intel(R) PRO/Wireless 2200BG WIfi working on ThinkPad T43
#2 Post by kfzhu1229 » Mon Oct 02, 2017 10:38 pm
I have the same card and i have problems with the public ones (either no password protection or log in with an account) in Windows 7. I recall many of mine and many of my friends Windows 7 laptop have the same problem with those wifi. Somehow mysteriously, upgrading to Windows 10 on my T43 machines and the problem vanished!
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
Flexview UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10
#3 Post by RealBlackStuff » Tue Oct 03, 2017 7:02 am
Now is the time to upgrade to 300Mbps wifi-N!
It's never been as cheap as this!
TP-Link TL-WN861N http://www.ebay.com/itm/292042300011
(I'm not related/connected to seller)
jamesfx2
#4 Post by jamesfx2 » Mon Oct 23, 2017 8:54 am
I don't think they managed to remove the Wifi whitelist on this model.
#5 Post by axur-delmeria » Mon Oct 23, 2017 9:13 am
But they have! http://thinkwiki.org/wiki/Problem_with_ ... ified_BIOS
The modified BIOSes there remove both the wifi whitelist and the annoying Error 2010 that appears when a non-Thinkpad HDD is installed.
Toy: X60/s Frankenpad Core Solo U1300
RIP: 760XD 9546-U9E, X61 T7500
:cry:
#6 Post by ajkula66 » Mon Oct 23, 2017 9:22 am
Indeed. I have been using TP Link "n" cards on my T43/p units for years now.
AARP club members:A31p, T42, T43pSF
Abused daily: T61p
jamesfx2
#7 Post by jamesfx2 » Thu Oct 26, 2017 4:49 am
http://www.thinkwiki.org/wiki/Problem_w ... twork_card implies that it doesn't fix the problem
NOTE!
On the R32, T43, X41, X60, W500, X230 and probably others, the BIOS hacks and the "no-1802" utility don't work.
Might give it a try. Can't even get the card working in Windows XP enough to connect to a WPA2 Wifi network.
#8 Post by RealBlackStuff » Thu Oct 26, 2017 7:53 am
Get the matching BIOS update here: https://archive.org/details/T43SLIC2.17 ... 0ByTTAV134
Get that TP-Link wifi card that I mentioned earlier.
Get drivers for that card here: http://www.atherosdrivers.com/
End of story.
