T42p's battery won't charge while the laptop is turned off
I have T42p, working new battery, working charger.
The issue is that the laptop won't charge the battery while it's turned off and the battery indicator on the screen panel does not shows up.
But as soon as I turn on the laptop, battery start charging and indicator shows up.
Also the battery runs out in this laptop about 2hrs, and at this time this battery works about 4hrs in the R50e (with almost identical specs).
Does anybody knows how to fix that? Thanks!
560Z, x31, X41, X61 IPS mod, x13 4750u
Re: T42p's battery won't charge while the laptop is turned off
So, I dismounted the motherboard but can't locate any blown fuses or other fired up components.
Can anybody help to locate the problem?
Here are the images (about 2 Mb for each)
Back 1
Back 2
Back 3
Back 4
Front 1
Front 2
Back 1
Back 2
Back 3
Back 4
Front 1
Front 2
This is only a guess:
I suspect your charger may not supply the proper voltage and a possible Thinkpad's Z-Diode blocks the current. Only if you feel safe for electrical testing you may measure the charger's output voltage on the plug you insert into the Laptop. Be carefull, that you do not short plus> and <minus> and irreversible damage your charger. Look at your charger"s imprint for the voltage output. If you try a different charger be aware that many of them deliver a 3V higher voltage (19V) then the IBM charger (16V).
For a workaround, try charging while suspend to RAM (stand-by) and give uspend to disk (hibernate) a try too.
Enjoy vintage computing, Mac-Chatter
Working Vintage Stuff:
ASUS X72N, WinVista-32; DualCore 2,5Ghz; RAM 6GB; SSD (SATA): 480GB; Gavotte RAMDISK: ~2,5GB (PAE) for pagefile
IBM T41; XP-Pro; RAM: 2GB; SSD (IDE=>SATA):128GB; RAMDISK: 760MB pagefile
Medion 95400; XP-Home; P-1,7GHz; RAM: 2GB; SSD (IDE): 64GB; RAMDISK: 760MB pagefile
Cannot see any of those pictures!
(Using PaleMoon browser 27.6.1)
Happens regularly, that's why I advise to use the likes of Imgur instead.
403. That’s an error.
Your client does not have permission to get URL /gi9e1ZS-8QI76sqytDT14hEEEh1dhbyxMGq7JvgvZauodu36pEzCaZmOjMkrgPJpiFNO6ic-zvHOLFdq43u3=w1920-h873-rw from this server. (Client IP address: xx.xx.xx.xx)
Forbidden That’s all we know.
RBS ... thanks for clearing things up about the images. I also see the same google message. I was wondering if it was my browser or still using WinXP.
Sorry, here is the new link with all images https://imgur.com/a/bBidl (also updated links at the top)RealBlackStuff wrote: ↑Sat Dec 02, 2017 7:38 amCannot see any of those pictures!
(Using PaleMoon browser 27.6.1)Happens regularly, that's why I advise to use the likes of Imgur instead.
I have 2 original 16V 4.5A IBM chargers and both are fine.
No not at all same specs, GPU wise. the Radeon 9600 / FireGL X2 in T42p is so much more power hungry than the integrated graphics. Also IPS screens takes more juice. I noticed those things one by one as I gradually turn my T43 into a T43p.maxcreations wrote: ↑Wed Nov 22, 2017 1:20 pmAlso the battery runs out in this laptop about 2hrs, and at this time this battery works about 4hrs in the R50e (with almost identical specs).
My suggestion as to why it doesn't charge while powered off:
1. check where you routed the BT antenna if you did not use it, I had that same problem before on my T43 only to find out that the contacts on the BT antenna shorted out some components on the top left corner.
2. check where the metal parts of the palmrest go to. I accidentally bent one of the metal parts by my keyboard and also shorted out some other components.
3. Use multimeter to test your fuses. I had seen several blown fuses on mobos, but none of what I seen can be diagnosed just by a pair of eyes, and they only show after a conductivity test.
4. If you wanna to go all out and do labour work, take the mobo out of its casing completely and attach the bare minimums (fan, CPU, battery, LCD cable + inverter) and see if it charges while powered off
600 PII-266 416mb 40gb WXP
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10 (Sharp)
UXGA:
detachable battery does not charge. White light, then amber, then off.
by redglow » Wed Nov 01, 2023 6:12 pm » in ThinkPad T430-T490 / T530-T590 Series - 2 Replies
- 9869 Views
Last post by redglow
Fri Nov 03, 2023 2:05 am
X260 something loose inside making a clunk when it's turned over
by Tired » Fri Feb 23, 2024 11:55 am » in ThinkPad X230-X280 / X390 Series - 4 Replies
- 547 Views
Last post by mikemex
Sat Mar 02, 2024 2:19 am
HELP! My X230 decided not to charge my non-genuine battery.
by canonmasta » Fri Dec 08, 2023 5:31 pm » in ThinkPad X230-X280 / X390 Series - 1 Replies
- 10810 Views
Sat Dec 09, 2023 12:07 am
Can you charge a T23/T30/T40 battery in a T60?
by RealBlackStuff » Sat Dec 30, 2023 11:34 am » in Thinkpad - General HARDWARE/SOFTWARE questions - 4 Replies
- 3865 Views
Tue Jan 09, 2024 3:09 pm
Users browsing this forum: No registered users and 49 guests
