T42 fan
T42 fan
Need help Identifying fan wires on t42 fan to test the fan. 1) red----- 2) blue---- 3)orange--normally red would be pos+ while black is neg- I'm guessing orange is the signal wire?? I don't want to cook it if it's good. If it is there's other issues I need to look into. I've tried online but all I can find is how to replace it.
Re: T42 fan
Get a multimeter and place the leads on the MoBo. Or just replace it.
I've replaced the fan before -- it's not worth it. Replace it + heat sink -- much easier.
Re: T42 fan
Pretty sure from when I tested them it's red and blue and then the fan will spin at full blast.hixs wrote: ↑Tue Sep 06, 2022 6:14 pmNeed help Identifying fan wires on t42 fan to test the fan. 1) red----- 2) blue---- 3)orange--normally red would be pos+ while black is neg- I'm guessing orange is the signal wire?? I don't want to cook it if it's good. If it is there's other issues I need to look into. I've tried online but all I can find is how to replace it.
If the fan feels noticibly jammed you can carefully pry open the housing, pull the fan blades directly off and then lubricate the fan.
If the fan spins freely when you touch it but still won't spin on the laptop and gives you a fan error, and testing it directly with red and blue doesn't spin either, you gotta replace it.
600 PII-266 416mb 40gb WXP
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10 (Sharp)
UXGA:
Can I replace my T440p stock fan with a Noctua fan?
by cultOfThinkpad » Wed Jan 10, 2024 2:41 pm » in ThinkPad T430-T490 / T530-T590 Series - 4 Replies
- 1658 Views
Last post by keithsketchley
Mon Feb 26, 2024 10:04 am
Unconnected black wire on fan T440P
by euless » Thu Nov 23, 2023 6:22 am » in ThinkPad T430-T490 / T530-T590 Series - 6 Replies
- 2138 Views
Last post by euless
Fri Nov 24, 2023 1:48 pm
T4x fan compatibilty.
by Gonzaleitor » Fri Feb 16, 2024 11:19 am » in ThinkPad T40/T41/T42/T43 Series - 0 Replies
- 301 Views
Last post by Gonzaleitor
Recommended OS for the T42?
by trylgsk » Thu Jan 18, 2024 4:20 am » in ThinkPad T40/T41/T42/T43 Series - 10 Replies
- 2201 Views
Sat Jan 27, 2024 1:22 pm
Users browsing this forum: Bing [Bot] and 26 guests
