Hello. I have a T42 laptop, model 2373, which is refusing to power on.
With the battery inserted and the laptop connected to DC power, the orange battery light is on. However, as soon as I hit the power button, this light goes off and the laptop remains unresponsive.
If the device operates without a battery and solely on DC power, there are no lights indicating activity and the laptop continues to stay inactive.
I'd appreciate it if you could provide me with some guidance on this issue.
Update #1:
It's a bit silly. I found out that it was because the battery had been too low. All I needed to do was to let the battery charge for a while. Then, I could turn the computer on.
My T42 wont power on
Re: My T42 wont power on
Did it turn on? If not, try removing the hdd or clean the rams or replace them.
Yes, the laptop is currently operational. However, a new issue has arisen. Once the laptop is switched off, it refuses to power back on, unless I disconnect and reconnect the battery.
Could it be the battery connector is corroded/dirty? Try wiping it with a q-tip and rubbing alcohol, then let it dry for a little bit before plugging the battery back in.
T430 (1vyrain bios, SSD, 16gb ram)
- 14 Replies
- 1786 Views
Last post by kapija
Wed Mar 27, 2024 1:46 pm
ThinkPad T530 Very little power, Will not power on
by ThinkPad560X » Sun Mar 10, 2024 12:42 am » in ThinkPad T430-T490 / T530-T590 Series - 2 Replies
- 419 Views
Last post by ThinkPad560X
Sun Mar 10, 2024 12:57 pm
ThinkPad T460 refuses to stay on after power button is pressed
by Fropple! » Fri Dec 08, 2023 1:31 am » in ThinkPad T430-T490 / T530-T590 Series - 0 Replies
- 7809 Views
Last post by Fropple!
P14s Losing Power When OFF
by tenplus1 » Sat Dec 16, 2023 5:22 am » in ThinkPad P1/P40/P50/P70 and later Series - 7 Replies
- 2003 Views
Last post by tenplus1
Fri Jan 05, 2024 6:42 am
