T43 shuts down 15 minutes into XP install
Hi Everyone
I've got a really nice T43p which just turns off (no warning or anything) after about 15 minutes....
Any ideas!?
Alex
Any ideas!?
Alex
WANTED: 220, 300, 300C, 315D, 320, 330x, 345x, 350x, 355x, 365x, 385x
500, 510, 530CS, 700, 730TE, 750, 750C, 750P, 755CD, 760x, 765x,
ANY 8xx Series, A20P, A21p, A22p, A31p, R50p, R52, T40p, X23/4, X40
Re: T43 shuts down 15 minutes into XP install
Overheating of the Southbridge comes to mind!
Big chip under the wifi-card.
Thanks to that stupid RoHS agreement, this was one of the first uses of lead-free solder, which they 'applied' in a very poor way.
I second this, in any case, just repaste the CPU also as you're already opening the system.RealBlackStuff wrote: ↑Tue Sep 12, 2023 11:49 pmOverheating of the Southbridge comes to mind!
It's very hot underneath and I think the 120Gb Seagate drives I use get very hot during the initial install due to all the fast reading and writing.
I have done it before but could do with a memory jog, once I get into the motherboard, can I just clean with IPA and re-thermal paste the CPU and the Southbridge?
CPU is normal paste refresh.
Southbridge does not have any means of cooling, other than permanently removing the wifi-card and attaching cooling ribs on that big Intel chip.
Why don't You try putting a thermal pad or a Cooper shim making contact with a metal part of the heatsink so it can disipate the heat? A little frankensteiny but may work. I'll also recommend repasting the GPU and CPU. Other thing You can try is getting the hdd drive out and install XP from another computer. Then, after You finish the installation put it back in the T43 and install all the drivers.solidpro wrote: ↑Wed Sep 13, 2023 7:08 amIt's very hot underneath and I think the 120Gb Seagate drives I use get very hot during the initial install due to all the fast reading and writing.
I'm assuming, 1) CPU, 2) Forgotten what this is, but seem to remember if the machine won't boot it could be because this one's solder joints have failed, 3) GPU, 4) Southbridge?
Only 1 and 3 have a built -in heatsink.
4 just sits there, under the wifi card, baking. I'll see if anything copper will attached to it...
I cleaned and put new MX-4 paste on both the CPU and the GPU, even though the GPU wasn't meant to have any (it has one of those rubbery pads). I'm running it with the palmrest off and it still seems to be a bit doggy.
I think the whole thing is flawed. What a lovely, terrible machine!
Oh BTW I ran the machine just in BIOS and it didn't shut down so I knew it was something about higher load.
I have 'fabricated' some makeshift shims/bits of copper to try and help absorb just a little bit more heat than before:
Seems chip 2 can take a pad and a bit of metal on it to more firmly touch with something-or-other on the base of the keyboard.
The gap between the southbridge and the wifi card is slender, so I folded over a piece of copper and put a pad under that and then the wifi card holds it in place.
I think actually some of the slowdown was to do with a very slow optical drive. It's all working OK now, but I dread to think how it would work in more heat.
Nice to see that i'm not the only crazy one making bizarre cooling solutions...solidpro wrote: ↑Wed Sep 13, 2023 1:20 pmOh BTW I ran the machine just in BIOS and it didn't shut down so I knew it was something about higher load.
Maybe you can connect a copper pipe to the card bus slot so it disipates through that. IIRC it was a "solution" for the T60 ATI GPU chip overheating, and they are in similar places.
Hmmm. Although it's a lovely machine I'm kinda regretting getting into it now. The machine took an install of XP no problems, and by default went to it's own native high resolution and then I plugged in a USB stick to copy over the drivers, had to reboot and it bluescreens now with or without the USB key plugged in.
It's like the XP has committed suicide. A version I've used over and over without issues.
The machine has gone back into a parking bay for when I have more patience.
I had success using the XP install CD to do a repair of my T60p's XP when it self-destructed.
It was more effective than Win 10's UEFI "startup repair".
Present interests: lenovo P71 4K i7 7700HQ P3000 20H2 - lenovo 25 FHD i5 7300U 22H2 - lenovo X330 WQXGA i7 3615QE NT6.1 - IBM lenovo R61i UXGA T9500 NT6.1 - IBM lenovo X61s SXGA+ T8100 22H2 - IBM A31p UXGA SL6V9 NT5.1
Did you try to reinstall the whole OS? Maybe you can try with EasytoBoot vía USB. It's the method I use and it's been very effective. Is your T43 SATA modded?solidpro wrote: ↑Thu Sep 14, 2023 7:07 amHmmm. Although it's a lovely machine I'm kinda regretting getting into it now. The machine took an install of XP no problems, and by default went to it's own native high resolution and then I plugged in a USB stick to copy over the drivers, had to reboot and it bluescreens now with or without the USB key plugged in.
It's completely original IDE. It won't even stay on long enough to run the initial setup of XP again now.... These machines seem very flaky nowadays....
i've never seen another laptop with 4 big, hot running chips all placed in a cluster like that. they'd have to have made it way larger to fit proper cooling in, shame really. that combined with the early lead free days is not gonna go well on a laptop like that one. i just hope that mine doesn't die on me.
from the stars in the sky
When I used to use the ThinkPad T43p daily, what I end up doing was using custom Chinese flattened copper pipes and one thin copper shim and then epoxy that on, bend the pipe into shape and dissipate heat onto the PCMCIA cage. It was effective for sure because after that mod the left palmrest plate gets much hotter than before. But again, what end up happening instead was the GPU solder balls giving up the ghost (screen goes blank until I push on the GPU)Gonzaleitor wrote: ↑Wed Sep 13, 2023 7:49 pmNice to see that i'm not the only crazy one making bizarre cooling solutions...![]()
600 PII-266 416mb 40gb WXP
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10 (Sharp)
UXGA:
Do the other T4Xp models suffer the same problems?
Yes and no. earlier T4x models suffer from graphics issues as a result of insufficient cooling on the graphics chip (and flexing again)!
You can transplant everything inside an R5x chassis if you don't mind some extra bulk, it would come with a much more rigid bottom chassis (and better cooling).
UXGA:
UXGA:
In the past I worked on well over 150 of those (dGPU only) T43/R52 mobo's to SATA-mod them.
For that (among other things) I removed the square IC left of your No. 4 (Southbridge).
FYI: that square IC is not a heat-source.
Is the R chassis really better? I thought the T40 chassis is CFRP while the R50 feels a lower grade of plastic. I have an R50p suffering from Southbridge detachment and a newer Lenovo-branded unit that died from GPU failure.
Having seen an R52 with broken chassis and lid plastics, it's a hard sell. But the taller/thicker bottom chassis does result in a beefier cooler.
Old Faithful: X220 4291-C91 i7-2620M
yeah that is true but I thought from my experience with R51 the bottom chassis does flex a bit less so maybe that would help some?
UXGA:
UXGA:
My idea is more that flex cannot and should not be totally eliminated, and a reasonable amount of flex must be anticipated, accepted, and tolerated in a laptop. Even magnesium frame has some give. Skyscrapers are engineered to bend, rather than break.
My opinion is the fault is entirely in the bad solder that fails to withstand normal flex and normal heat. I always felt like T40 series with CFRP base and high grade palmrest and metal lid is incredibly sturdy feeling, actually with a better feel than my T500 with its internal structure frames also in CFRP base but topped in cheap plastics (R500 is a little thinner plastic). But T500 is the more reliable laptop.
I'm not sure why the popular opinion is to blame flex. Everything flexes.
Leave out the Wifi card - you won't need it for the install?RealBlackStuff wrote: ↑Tue Sep 12, 2023 11:49 pmOverheating of the Southbridge comes to mind!
I once had a similar problem installing WinXP on a Thinkpad R50E. When trying to install, it would hang at a random time.
It turned out that one RAM chip is defective. I installed the system correctly on one working RAM.
390X,570E,600E,iSeries1200,A21m,A30P,A31,A31P,G40,R30,R31,R32,R40,R40e,R50,R50e,R51,R51e,R52,R60,R400,
T20,T21,T22,T23,T30,T40,T41,T41P,T42,T43,T60,T400,X24,X30
The R Series has stood the test of time better. They are larger, thanks to which they give off heat better, and they do not have the sticky cover like the T series.
Hey, has anyone tried putting a thermal pad in the southbridge to disipate through the wifi card? It's too crazy to think that?
Back when I dailied a T43p, I went all out and put some flat copper heatpipes inbetween them and wick the heat to the PCMCIA cage. That definitely did its job well in my case because the GPU was the one that failed instead.Gonzaleitor wrote: ↑Tue Nov 14, 2023 8:26 pmHey, has anyone tried putting a thermal pad in the southbridge to disipate through the wifi card? It's too crazy to think that?
UXGA:
UXGA:
I was thinking that, But meanwhile i use the mini pci Card as a heatsink with a 2mm thermal pad
Yeah that is definitely better than having nothing indeed.Gonzaleitor wrote: ↑Wed Nov 15, 2023 6:04 pmI was thinking that, But meanwhile i use the mini pci Card as a heatsink with a 2mm thermal pad
UXGA:
UXGA:
Is that better or is that worse? the card itself gets hot, wouldn't that just move more heat onto the southbridge?
T520's NVS 4200M quits after 15-ish minutes of load
by FuzzleSnuz » Sun Jul 09, 2023 11:15 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 8 Replies
- 4009 Views
Last post by TPFanatic
Fri Jul 21, 2023 4:41 pm
Thinkpad x60s not shutting down all the way from linux
by nicefisher » Sun Jul 23, 2023 6:55 pm » in Linux Questions - 7 Replies
- 4911 Views
Last post by nicefisher
Thu Nov 23, 2023 8:29 pm
Strange 701C Issue - Computer Keeps Shutting Down
by jnnelson79 » Sat Aug 05, 2023 10:27 am » in ThinkPad Legacy Hardware - 4 Replies
- 4137 Views
Sun Aug 06, 2023 2:27 am
RBS website TheBoardRoom has closed down.
by RealBlackStuff » Sun Jul 30, 2023 7:36 am » in Off-Topic Stuff - 3 Replies
- 6003 Views
Last post by solidpro
Sat Aug 05, 2023 4:18 am
