T60 touchpad flex cables
Does anyone have a few T60 touchpad cables for sale? Fingerprint version. They do seem to be extremely fragile at the bend by the touchpad connector.. And eBay doesn't seem to have any at all
In use:
T450s: max spec
Occassional use:
T60: 15" 4:3 IPS, T7600G 2.66GHz, x1400, T61 fan, 120GB SSD, 3GB RAM, 4965AGN
Museum:
T20 @900mhz. X31 @1.4Ghz. T60 14"
Retired:
A20. T61p. T500. X220. T420. T420s. T430s
T450s: max spec
Occassional use:
Museum:
Retired:
Re: T60 touchpad flex cables
the cables are flatflex and cannot be replaced without replacing the entire palmrest.
Sorry but that is not true, they are easily removable if handled with care
In use:
T450s: max spec
Occassional use:
Museum:
Retired:
T450s: max spec
Occassional use:
Museum:
Retired:
I dont exactly understand the part you would like to replace. Can you list a picture or part number? Also, is it a Widescreen or Fullscreen T60?iganas wrote:Sorry but that is not true, they are easily removable if handled with care
EDIT: Sorry, I was thinking about thr T4x touchpad to T6x touchpad. I have one should be able to use.
PM sent, thanks.
I guess the main lesson here is to be very gentle with that cable while disassembling the actual touchpad plate, as peeling off the protective tape from the back of it introduces side tension that is strong enough to cause a small tear on the flex cable
Here's a photo of the tear:
www.dropbox.com/s/4c24ff66l5u1dbr/IMG_2 ... 9.jpg?dl=0
In use:
T450s: max spec
Occassional use:
Museum:
Retired:
T450s: max spec
Occassional use:
Museum:
Retired:
FlatFlex, more like FlatRip
Would you like a Full Palmrest, I have one for 14" 4:3 T60. In good condition AFAIK.
PM sent.
Would like to bump this up, as I'm still in search for one more touchpad flex cable
In use:
T450s: max spec
Occassional use:
Museum:
Retired:
T450s: max spec
Occassional use:
Museum:
Retired:
Left To Right / Right To Left LCD Converter Extender Cables
by TPFanatic » Wed Jan 17, 2024 6:19 pm » in Off-Topic Stuff - 0 Replies
- 903 Views
Last post by TPFanatic
X230 Precision Touchpad
by TPFanatic » Tue Feb 06, 2024 9:25 pm » in ThinkPad X200/X201/X220 and X300/X301 Series - 0 Replies
- 510 Views
T460s - Touchpad doubleclicks occasionally when clicking once
by Sanras » Sat Mar 23, 2024 5:19 pm » in ThinkPad T430-T490 / T530-T590 Series - 0 Replies
- 198 Views
Last post by Sanras
Useful improvement of x230 touchpad functionality
by TOTAL » Wed Mar 27, 2024 9:09 pm » in ThinkPad X230-X280 / X390 Series - 0 Replies
- 160 Views
Last post by TOTAL
Users browsing this forum: No registered users and 50 guests
