Hello everyone,
actually I concider myself to be rather fit in ThinkPad-related questions, but now I have one issue, which bothers me since a couple of weeks, and I have no Resolution for it. Perhaps, some of you could give me a hint.
I have TP T60p, and sometime ago I noticed that it started to loose the time. I bought at eBay new CR2032 battery, and replaced the old CMOS battery with a "Hand made" one (red wire on the "+", a black one on the "-"). Unfortunatelly, it brought nothing - as soon as I remove the Laptop battery, my BIOS clock is reset. I have replaced my CR2032 twice (thinking, it is a bad/used one), I also switched the wires - no effect. Does anyone of you have an idea, what happened with my BIOS/CMOS?
In the past I replaced CMOS batteries on 600x and T22/23 - it worked. Here it doesn't. No idea why.
Thganks in advance, best regards from Hamburg/Germany
Andrey
Replacement of CMOS battery: no effect on clock
- in use -
(1) TP R61i Frankepad - 4 GB / C2D T9500 / 180 GB SSD / UXGA display
(2) Lenovo 3000 N200 - 2 GB / C2D T7300 / 160 GB
(3) TP T450s
- in museum -
IBM 600x, IBM TP T43p, Lenovo TP Z61t, Lenovo TP X60 Tablet
(3) TP T450s
- in museum -
Re: Replacement of CMOS battery: no effect on clock
You can get ready-made CMOS batteries galore.
Anything from T20-T61 and several newer ones will fit.
However, if you make a mistake like swapping + and - you could have blown the BIOS (in which time/date is stored).
I'd suggest you try and reinstall BIOS first, making sure you have a working CMOS battery (~3V with a multimeter).
Hello @RealBlackStuff,
Thanks for your hint.
I cheked my BIOS Version - it is not the latest one (2,23 instead of 2.27). So, I plan to reinstall BIOS using the CD from Lenovo site. I hope, this will help.
I decide to use "home made" battery, because I managed to do it in the past easily, without an issues.
Regards,
Andrey
Regards,
Andrey
- in use -
(3) TP T450s
- in museum -
(3) TP T450s
- in museum -
just decided to post an update: the reason was that "self-made" battery. I updated BIOS, installed "the real" CMOS battery (bought at eBay) - and it works. Somehow it didn't work this time with a self-made one. But the battery itself (CR2032) was not the reason - I placed it today into my 600x (which also had dead CMOS battery) as self-made replacemenet, and it also worked. So, most probably, the cable/connector were damaged.
So, the issue is resolved.
Andrey.
Andrey.
RealBlackStuff wrote: ↑Tue Aug 08, 2017 4:46 amYou can get ready-made CMOS batteries galore.
- in use -
(3) TP T450s
- in museum -
(3) TP T450s
- in museum -
X131e Bad CMOS Battery - Unresponsive
by PinkFloydEffect » Sat Feb 17, 2024 1:29 am » in ThinkPad X100e/X120e/X130e/X140e Series - 2 Replies
- 1033 Views
Last post by PinkFloydEffect
Sat Feb 17, 2024 2:28 pm
x230 Wi-Fi card replacement and external antenna
by Teddy98 » Sat Oct 21, 2023 9:39 am » in ThinkPad X230-X280 / X390 Series - 5 Replies
- 3055 Views
Last post by Qing Dao
Sat Dec 16, 2023 9:59 am
380ED display panel replacement - Type 1 and Type 2 panels?
by KylesDigitalLab » Thu Oct 26, 2023 11:26 pm » in ThinkPad Legacy Hardware - 0 Replies
- 2360 Views
Last post by KylesDigitalLab
X230T Keyboard trackpad button issue replacement?
by blink » Mon Nov 06, 2023 8:29 am » in ThinkPad X230-X280 / X390 Series - 3 Replies
- 2593 Views
Thu Nov 09, 2023 10:59 am
