Thinkpad T60 Motherboard Swap OK?
I have an IBM Thinkpad T60 14.1" non-widescreen and I want to upgrade my motherboard to a better on that has penryn support and a better gpu with little/no case modification.
Thanks in advance!
Is this a good choice: https://www.ebay.com/itm/42W9380-IBM-LE ... Sw9idZ5mVD
Thanks in advance!
Re: Thinkpad T60 Motherboard Swap OK?
"Pulled from a new T61"
These systems were discontinued by mid 2008...and we're at the end of 2017.
Abused daily: T520, X200s
My new T61, X301 and HP Compaq NX32**?
They are out there, but I really HIGHLY doubt it was new.
Ignoring the fact that this motherboard isn't new, would this be a good motherboard for my thinkpad upgrade?
If I'm not mistaken, that's a planar with Intel integrated graphics, not nVidia. Presuming that you're OK with that fact, it should work fine.nightninja96 wrote: ↑Sun Oct 22, 2017 8:33 amIgnoring the fact that this motherboard isn't new, would this be a good motherboard for my thinkpad upgrade?
What exactly do you mean by thinkpad planar. I'm kind of new to this frankenpad thing.
Planar is IBM/Lenovo term for motherboard.nightninja96 wrote: ↑Sun Oct 22, 2017 1:28 pmWhat exactly do you mean by thinkpad planar. I'm kind of new to this frankenpad thing.
Will a 15" non-wide screen motherboard work in my 14" thinkpad? I am worried about this because I read something about 15" motherboards not working with 14" thinkpads due to the motherboard being physically obstructed and the 15" motherboard would output for 1 15" screen not 14".
The 15 and 14 nonwide boards are identical. The only difference is the 15" units have an interposer card to make up the difference inside the case, but just slides in to the board.
So do you all think that the board i mentioned before (https://www.ebay.com/itm/42W9380-IBM-LE ... Sw9idZ5mVD) would be a good choice for my project. My project is to mod the bios to support 8gb of ram, sata II speeds, and penryn cpus then I'm planning to install this cpu (https://www.ebay.com/itm/Intel-Core-2-E ... 2548.l4275) and add an ssd to the thinkpad.
You can't install an X9100 without a pinmod along with a different BIOS mod from one that is most commonly used (Middleton's).nightninja96 wrote: ↑Sun Oct 22, 2017 2:47 pmSo do you all think that the board i mentioned before (https://www.ebay.com/itm/42W9380-IBM-LE ... Sw9idZ5mVD) would be a good choice for my project. My project is to mod the bios to support 8gb of ram, sata II speeds, and penryn cpus then I'm planning to install this cpu (https://www.ebay.com/itm/Intel-Core-2-E ... 2548.l4275) and add an ssd to the thinkpad.
How difficult is it to perform the "pin mod" and how would I do it?
If you have to ask then you've already answered your own question...nightninja96 wrote: ↑Mon Oct 23, 2017 3:12 pmHow difficult is it to perform the "pin mod" and how would I do it?
How do I perform the pin mod.
Search the forum!
Where can I find this bios that supports the x9100?
Also, on the forum. Everything you need is here.
Nightninja,
What the experts here are politely trying to say is that you are getting in Way over your head. I don't even want to mess with pinmods and I'm pretty adept. But if you want to try it, there are a couple of threads that go into great detail. You Cannot do this with just the Middleton BIOS, you need the higsun one ( think), and that's on a German language forum. Be prepared to toss out everything, especially if you mess up that pin mod.
You should not need a BIOS mod to take a T61 system board to 8GB, but the 4GB modules are quite pricey, more than double the cost of the same size but newer DDR3 modules.
And you want to put this all into a T60. Well, good luck and keep us posted.
600 600X
760LD FUBARd
T41 T42 T43
T500 2
T530 W530
760LD FUBARd
T41 T42 T43
T500 2
T530 W530
ThinkPad T470 motherboard swap
by ThinkPad560X » Tue Mar 19, 2024 12:57 am » in ThinkPad T430-T490 / T530-T590 Series - 10 Replies
- 354 Views
Last post by ThinkPad560X
Wed Mar 20, 2024 9:39 pm
X1C5 and X1C6 motherboard swap?
by mikemex » Mon Dec 25, 2023 4:19 pm » in ThinkPad X1 / X1-Carbon / X1-Extreme and later Series - 2 Replies
- 1724 Views
Last post by mikemex
Tue Jan 09, 2024 7:32 pm
Any considerations with this mobo swap?
by canonmasta » Sun Nov 19, 2023 4:36 am » in ThinkPad X230-X280 / X390 Series - 5 Replies
- 5165 Views
Sat Dec 16, 2023 10:30 pm
Cpu swap gone wrong.
by Timroin » Sun Jan 21, 2024 5:16 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 5 Replies
- 996 Views
Tue Jan 23, 2024 1:15 pm
