Good for my frankenpad
nightninja96
#1 Post by nightninja96 » Fri Oct 27, 2017 8:04 pm
Hello, I can't find a bios for my frankenpad. My frankenpad features a 14.1" 4:3 screen and an integrated intel graphics card. I want to install a c2q q9100 but I can't find the modified bios for my machine.
Thank you for your help
el-sahef
Re: Good for my frankenpad
#2 Post by el-sahef » Sun Oct 29, 2017 8:12 am
https://thinkpad-forum.de/threads/172581
They all work on any T61 with Intel graphics.
T70 15" 4:3 QXGA @ daylight LED, Core i7 7700HQ, 16 GB RAM, SSD
X62t, SXGA+ @ daylight LED,
T70 i5 WUXGA RGB-LED
600X @ Ivy Bridge Core i7 1,9 GHz
nightninja96
#3 Post by nightninja96 » Sun Oct 29, 2017 9:23 am
Which bios is the best bios for me, I am getting a c2q q9100.
Thinkpad4by3
#4 Post by Thinkpad4by3 » Sun Oct 29, 2017 9:32 am
Ok, You have to fill out the following:
Do you want a quad core: yes.
Do you want nVidia underclock: doesn't matter (would recommend standard voltage)
Do you want Active System Power Management: That is up to you!
Do you want nVidia overlock: doesn't matter (would recommend no)
Now pick a bios that fits the following specs above and install it!
Probably should be Thinkpad16by10.
Looking For: 386 laptop, IBM or not.
nightninja96
#5 Post by nightninja96 » Sun Oct 29, 2017 10:57 am
Ok, I picked the modded bios that best suits me, now I have to get the newest bios from lenovo. I have to flash the official (Lenovo bios) then re-flash my system with modded bios. I can't find a official bios for the t61 that supports non-widescreen.
Thinkpad4by3
#6 Post by Thinkpad4by3 » Sun Oct 29, 2017 11:00 am
AFAIK, all T61's use the same BIOS, regardless of widescreen or not.
nightninja96
#7 Post by nightninja96 » Sun Oct 29, 2017 12:49 pm
When I install the modified bios do I have to have my officially supported CPU in (t7200) or do I put my q9100 in before I install the modded bios?
Thinkpad4by3
#8 Post by Thinkpad4by3 » Sun Oct 29, 2017 1:39 pm
I doubt the machine will even boot with an unoffical CPU so installing without it would theoretically be impossible.
Cigarguy
#9 Post by Cigarguy » Sun Oct 29, 2017 2:26 pm
If one needs BIOS x to install CPU y, it would seems logical really. Otherwise there's no need to install said BIOS and CPU y is indeed supported.
Users browsing this forum: Bing [Bot] and 11 guests
