Cannot install windows
killahtm
#1 Post by killahtm » Tue Nov 14, 2017 11:40 am
hi, i have t60 and i cannot install windows (i have tried win 7, win 10, from usb, from cd). It passes copying files and install updates and then after restart it freezes itself.
memory test ok, hdd test ok (also have tried with another hdd).
plz help me...
Thinkpad4by3
Re: Cannot install windows
#2 Post by Thinkpad4by3 » Tue Nov 14, 2017 1:19 pm
Which T60 CPU are you using. It is likely a T2400 which is 32bit only, not 64 which those OS are likely.
Probably should be Thinkpad16by10.
Looking For: 386 laptop, IBM or not.
theterminator93
#3 Post by theterminator93 » Tue Nov 14, 2017 1:28 pm
If he was trying to install the 64 bit flavor of any of those OSes with an x86 only CPU, it wouldn't get past the bootloader to install.
I have seen a few instances where immediately after the install and first reboot, the machine gets "stuck" at the Starting Windows screen for 1-2 minutes before moving on. It only does it once, so I'm not sure what it doesn't like...
Where exactly does it freeze? CMOS to defaults change anything?
Daily: T25 | W520 i7-2860QM·Quadro 2000m·IPS FHD | T420 i7-2640M·NVS 4200m·IPS FHD | X220 i7-2640M | T601F T9900·NVS 140M·IPS UXGA
Others: T61p·61·43·42p|X41T·24·23·22|G41|A31p·22m|i1200|TransNote|380D|365XD|701C|755C
killahtm
#4 Post by killahtm » Tue Nov 14, 2017 2:27 pm
i have t5600 and thats 64bit cpu, right?
it finishes copying files and install updates, then installation restart laptop and it freezes on booting, on first logo show.
i have tried load cmos defaults, no help.
#5 Post by dr_st » Tue Nov 14, 2017 3:14 pm
Are you installing to the internal hard drive or to a drive in the bay?
Are there any USB devices connected during the boot that freezes?
Can you boot in safe mode (after the installation is done copying files)?
Current: Thinkpad 25 (20K7), Yoga 14 (20FY), X220 4291-4BG, T410 2537-R46, T60 2007-QPG, T42 2373-F7G
Retired: X61 7673-V2V, T60 1952-F76, A31p w/ Ultrabay Numpad
killahtm
#6 Post by killahtm » Tue Nov 14, 2017 5:00 pm
Im installing on internal hdd.
Tried to disconnect usb after copying files not helping.
Cannot go to safe mode
cadillacmike68
#7 Post by cadillacmike68 » Mon Nov 20, 2017 8:02 pm
Pressing F5 or F8 when starting (I can never remember which) should allow you to load in safe mode.
760LD 9547 FUBARd
T500 2
killahtm
#8 Post by killahtm » Tue Nov 21, 2017 4:17 am
Its f8 but that dont help cause windows hasnt finished installation.
theterminator93
#9 Post by theterminator93 » Tue Nov 21, 2017 7:04 am
How long do you let it sit while it's at the first logo display during first boot before giving up on it?
Any change if you try the other HDD mode (AHCI/Compatibility) for install?
Last edited by theterminator93 on Tue Nov 21, 2017 7:06 am, edited 1 time in total.
killahtm
#10 Post by killahtm » Tue Nov 21, 2017 7:06 am
Tried that, same thing :(
Really frustrating....
#11 Post by axur-delmeria » Tue Nov 21, 2017 9:14 am
1. Does your T60 have Intel or ATI graphics?
2. What's its BIOS version?
Toy: X60/s Frankenpad Core Solo U1300
RIP: 760XD 9546-U9E, X61 T7500
:cry:
killahtm
#12 Post by killahtm » Tue Nov 21, 2017 5:07 pm
It has ati gpu and bios is 2.26.
You think anything change if i update to 2.27 or it exist newer bios?
#13 Post by dr_st » Wed Nov 22, 2017 2:58 am
I don't think there are any meaningful differences between 2.26 and 2.27 (which is the latest version for 4:3 T60).
https://pcsupport.lenovo.com/jp/en/downloads/migr-63024
killahtm
#14 Post by killahtm » Wed Nov 22, 2017 4:00 pm
Really cant believe what a stupid failure. I guess its time to retire my t60 :(
JBUK
#15 Post by JBUK » Thu Nov 23, 2017 8:02 pm
You could try booting from a Linux live CD or USB to prove the T60 hardware.
Also what happens if you skip installing updates? These have been known to kill a machine.
Where to begin......
390e x1 390X 390X,700mhz
1 x T20 + about 8 untested for spares
4 X T23 + 6 breaking for parts
1 X T23 with Samsung 840 SSD and XP Great combination !
AND NOW....3 X T60s and 3 x T61s
Cigarguy
#16 Post by Cigarguy » Thu Nov 23, 2017 8:06 pm
I've had this happen a couple of times while installing Windows 7 on various Thinkpads. Instead of trying to find the bug, I simply reinstall Windows and everything works even though the previous install did not work.
killahtm
#17 Post by killahtm » Fri Nov 24, 2017 3:37 am
That install updates is on windows 7 installation setup so i cannont stop it :)
I have tried installing several times win 7 and win 10, allways same error.
Will try live linux but i need windows on this laptop :(
JBUK
#18 Post by JBUK » Fri Nov 24, 2017 4:20 am
You can stop updates by having no internet connection available or disabling the Windows update service. Its worth a try to see if one of the updates is screwing the Tpad.
Another long shot, what Bios level do you have ? W7 not supported before 2.25.
Have you got another T60 to try installing on. I
As I am sure you know it should just work......
killahtm
#19 Post by killahtm » Fri Nov 24, 2017 4:29 am
Tnx, will try without internet. I have 2.26 bios
