T61 available RAM - confused
I have a dual boot 32bit XP and Win10 T61, well several actually. When 4gb of ram is installed both OSs report only 3gb available, BIOS says 4gb installed. I would expect a bit more than 3 gb as a 1gb loss to OS and Thinkpad overheads seems a bit too much I would have thought. This is based on my desktop which shows about 3.4 available.
The situation changes if I install only 3gb of RAM this shows as all 3gb available!! All T61 are the same and all are Intel graphics.
So that is 100% of 3gb and only 75% of 4gb available. Anyone know why this is ?
Where to begin......
390e FOR SALE : GONE
1 x T20 : SOLD
1 X T23 + 3 breaking for parts
1 X T23 with Samsung 840 SSD and XP Great combination !: SOLD
1 X T60
3 X T61
1 X T601 15"
1 X T520
2 X T530
1 x T20 : SOLD
1 X T60
3 X T61
1 X T601 15"
1 X T520
2 X T530
Re: T61 available RAM - confused
Nothing confusing, just 32 bit OS limitations. Lots have been written on this subject. 32 bit OS will only recognize 3 GB. Some Dell and HP laptops are able to recognize a bit more but never the full 4 GB. Install a 64 bit OS and you can install up to 8 GB on a T61.
This is actually an Intel chipset limitation and will apply to any other computer using this chipset. My sister's Acer Aspire model from 2006 has the same chipset, and it can only use 3GB of the 4GB installed.
W520 (C2Q i7-2720QM, 8GB, 60GB SSD)
X61s (2GB, 120GB SSD)
T43p (P M 760, 2GB, IBM Port Replicator II, 128GB SSD)
G41 (P4 3.46GHz, 2GB, 128GB SSD)
I'm fairly certain that you're referring to the chipset seen in T60, but OP's system is a T61 so it's a completely different ballgame.Shredder11 wrote: ↑Thu Nov 23, 2017 11:21 pmThis is actually an Intel chipset limitation and will apply to any other computer using this chipset. My sister's Acer Aspire model from 2006 has the same chipset, and it can only use 3GB of the 4GB installed.
Agreed with behaviour observed being tied to a 32-bit OS.
Abused daily: T520, X200s
To clarify, it is a limitation of 32-bit Microsoft Vista and 32-bit Microsoft XP.
There are 32-bit operating systems which use physical address extension (PAE) to address >4 GB. To give an example, 32-bit Red Hat Enterprise Linux has a memory limit of 64 GB.
It is not a chipset limitation. The chipset limitation is "8 GB maximum memory".
And Windows 7 and 8 and 10, and every Microsoft client 32-bit OS. Server SKUs can recognize more memory. The limitation, BTW, was introduced with XP SP2. SP1 had no this kind of limitation. But nobody had >4GB of RAM at that time.jaspen-meyer wrote: ↑Thu Nov 23, 2017 11:29 pmTo clarify, it is a limitation of 32-bit Microsoft Vista and 32-bit Microsoft XP.
There are unofficial patches that can unlock the limitation, but what's the point? Can just install a 64-bit version.
I am not convinced that this is totally a 32bit issue as my desktop will see 3.42gb of 4gb with the same PAE setup. I have tried some of those patches which open up RAM > 4gb and they do work but the downsides I found with USB support for example meant that the OS was unusable. I have not tried the WIN 10 patch yet though as I don't really like W10 enough on the T61.
So to try to diagnose further I will install XP SP1 and see what happens then. I am just curious thats all.
1 x T20 : SOLD
1 X T60
3 X T61
1 X T601 15"
1 X T520
2 X T530
1 x T20 : SOLD
1 X T60
3 X T61
1 X T601 15"
1 X T520
2 X T530
On a system limited to 4GB addressable RAM, some address space has to be reserved for devices. How much exactly differs based on the devices available, so different systems can end up with different amounts of addressable RAM.
Yes my mistake, the chipset is different and so the OS is the cause here on the T61 models.ajkula66 wrote: ↑Thu Nov 23, 2017 11:28 pmI'm fairly certain that you're referring to the chipset seen in T60, but OP's system is a T61 so it's a completely different ballgame.Shredder11 wrote: ↑Thu Nov 23, 2017 11:21 pmThis is actually an Intel chipset limitation and will apply to any other computer using this chipset. My sister's Acer Aspire model from 2006 has the same chipset, and it can only use 3GB of the 4GB installed.
Exactly, but how to find out exactly what is lost to system overheads when the loss is zero with 3GB of RAM installed and apparently 1GB with 4GB installed.
To investigate further I installed XP SP1 which will address memory above the 32bit 4gb limit and this showed that 3.92gb was available when 4gb was installed, a reported loss of 80mb. Then with 3gb installed 2.97 was available, a loss of 30mb.
So I am still puzzled where my 1gb of memory has disappeared to when XP and Win 10 report only 3gb when 4gb is installed. It is clearly down to windows but why is my Thinkpad penalized more than my desktop which only loses .58gb to system overheads.
1 x T20 : SOLD
1 X T60
3 X T61
1 X T601 15"
1 X T520
2 X T530
1 x T20 : SOLD
1 X T60
3 X T61
1 X T601 15"
1 X T520
2 X T530
If you found out, it would not help you. There is not much you can do with it.
As you see, XP SP1 succeeded in remapping most of your RAM. Some loss may be due to alignment (addresses can only be remapped in blocks, not one-by-one).
Again - XP SP2+ and later Windows client OSes (32bit) will not address anything over 4GB. So any address ranges reserved to devices are lost from RAM. How much is lost varies from system to system, depending on the hardware configuration.
Frankenpad 15" TuuS MB X9000, LED IPS, T440s IPS display
Toughbook CF51 with SSD, Dell: D830, M4400, M6400
Installing a WinXP SP1 for testing is okay, but installing a 64bit Windows for testing is too much? I don't understand you...
X62s 3rd batch, [s]T61[/s] T70 14" 4:3 1st batch
I hear you. Just install a 64 bit OS and move on. I don't know of any program that will run only 32 bit AND is not 64 bit OS compatible AND don't have AND will never have a 64 bit compatible version. I could be wrong.
16-bit Windows programs.
@dr_st: That's the reason I have the Windows Virtual PC "XP Mode" installed on my Win 7 64! I needed it to install legacy programs.
Confused what NVME adapter is compatible with my Lenovo Thinkpad T480
by Cyber Akuma » Sat Dec 30, 2023 7:32 pm » in ThinkPad T430-T490 / T530-T590 Series - 1 Replies
- 2154 Views
Sun Dec 31, 2023 1:17 am
Any A31 Bios update version 1GE... available?
by franjimo24 » Wed Jan 10, 2024 12:03 pm » in ThinkPad R, A, G and Z Series - 4 Replies
- 1444 Views
Last post by franjimo24
Thu Jan 11, 2024 10:23 pm
600e won't take any ram sticks
by Gonzaleitor » Mon Oct 23, 2023 11:30 pm » in ThinkPad Legacy Hardware - 2 Replies
- 5661 Views
Last post by Gonzaleitor
Tue Oct 24, 2023 9:50 am
FS: Intel Core i7-3630QM CPU + RAM
by PiZzA EnGiNeEr » Mon Oct 30, 2023 12:26 am » in Marketplace - Forum Members only - 1 Replies
- 2098 Views
Last post by wilocampo
Thu Nov 30, 2023 2:59 am
