SSD guide for T60P
T60/T61 Series
MichaelS
SSD guide for T60P
#1 Post by MichaelS » Sun Dec 10, 2017 7:27 pm
I've probably missed it, but where can I find instructions for configuring my T60P for an SSD?
Any recommendations on current SSDs? I'm looking for a reliable 500GB SSD in the $150 range.
Also, does the Middleton BIOS upgrade work for a T60P to enable SATA II speeds? And if so, where can I find it?
Many thanks.
TPFanatic
Re: SSD guide for T60P
#2 Post by TPFanatic » Sun Dec 10, 2017 7:37 pm
Middletons is for Santa Rosa T61, X61, and R61 only. Best T60's system board can get is the Zender's BIOS or equivalent no-whitelist BIOS for the WLAN and WWAN. T60 chipset is perpetually limited to SATA 1.
You can also "Frankenpad" the T60 with a 4:3 T61 systemboard, then you can put the Middletons BIOS on that!
I bought a "New" Micron 512GB SSD for $129 on eBay, using it in my T500.
geka3250
#3 Post by geka3250 » Mon Dec 11, 2017 12:09 am
There are no special recommendations about configuring SSD, just enable AHCI SATA mode in BIOS. You can use SATAI due to chipset limitations, ICH7M Southbridge doesn't support SATAII.
I don't know what SSD to recommend, Russian 3dnews site have reliability tests for a big amount of 256GB range SSDs. This can help in choosing right SSD.
Original link
Google translated
340CSE | 380XD | 770 | 770X | 770Z | 390E | 600E | 600X | T23 | X30 | T30 | T41p | T43 | T60p | X200t
Shredder11
#4 Post by Shredder11 » Mon Dec 11, 2017 6:49 pm
I've been using Crucial BX100 SSD and a few old crappy Intel X25-M Sandforce drives for the last five years. The Crucial drives seem good and perform well.
W520 (C2Q i7-2720QM, 8GB, 60GB SSD)
X61s (2GB, 120GB SSD)
T43p (P M 760, 2GB, IBM Port Replicator II, 128GB SSD)
G41 (P4 3.46GHz, 2GB, 128GB SSD)
theterminator93
#5 Post by theterminator93 » Mon Dec 11, 2017 7:03 pm
I've been using Crucial's drives for the last half-dozen years too and they have all been serving me well. I seek out MLC when it's in my budget, but avoid TLC and Sandforce. I haven't had issues with 3D-NAND so far but my experience with it has been relatively limited. Time shall tell...
T420 IPS FHD | X220 IPS FHD | T61p·T61·43·42p|X13 Yoga G3·220T·301·41T·24·23·22|G41|A31p·22m|i1200|TransNote
JGTC.co.jp
#6 Post by JGTC.co.jp » Sat Dec 30, 2017 9:32 am
I am currently using a Toshiba Q300 and an ADATA SP550 on both my Signature's machines. Both drives can cope with T60's improved perfromance, limited to SATA-I speeds. Even if you have not updated your BIOS in a while (more on that in another post), the SSD will be detected and I/O'd right away, no drama there.
JGTC.co.jp
The one that started it all: T60 1952-B68 (In plans of a rebuild)
Personal ones: T60 2007-46S - T60p 8741-A11 - R52 1860-A73 - 600E 2645-5JU - T540p 20BF-S02S01
Dekks
#7 Post by Dekks » Sun Dec 31, 2017 9:41 pm
Many thanks.
What OS? If it's Linux based on systemd then activate the fstrim timer service & change the io scheduler to noop via configuring grub.
Home - Win 10 MSi GF63 Gaming Laptop /Arch GNOME 3/X230 Tablet /X61 [Korean] - Debian 10/T60p - Ubuntu 20.10 Helix 2
Work - Win10/Thinkpad X1 Tablet Gen 2
