T61p - 4 or 6 GB memory
hopgarden53
#1 Post by hopgarden53 » Mon May 21, 2018 5:18 pm
is it better install 2 x 2 GB (= 4 GB) than 2 GB + 4 GB (= 6 GB - unofficially over 4 GB MAX) on a
a) T61p 6457-5GG
b) T61p 6457-CTO(WRJ)
c) X60 1707-YF8
d) X61s 7666-3AG
T61p (2), X61s, X60, X60 Tablet,T43, R51 1829-R6G, R50p, X40, X32, A31p, A31 2652-MYG, T30 2366-QG7, T23 2647-NG6, 600X (3), 600, 570E
ThinkStation D20, ThinkStation D10
PS2 Note N33x Type 8533
Re: T61p - 4 or 6 GB memory
#2 Post by RealBlackStuff » Mon May 21, 2018 7:11 pm
a) 2x4 GB
b) 2x4 GB
c) 2+1 or 2x2 GB (only 3GB usable)
d) 2x4 GB
Lovely day for a Guinness! (the Real Black Stuff). And pigs CAN fly! :mrgreen:
hopgarden53
#3 Post by hopgarden53 » Tue May 22, 2018 3:39 am
Well, thanks.
Actually I was asking if there is a performance penalty in using "odd size" memories? If I have only one 4 GB simm ...
#4 Post by RealBlackStuff » Tue May 22, 2018 6:43 am
Up to 2x2GB, the RAM will run in Dual Channel mode, the rest, above 4GB, will run in Single Channel mode.
Dual is slightly faster than single, but not by much, and not everywhere.
On such old machines you won't notice any difference anyway, so put in what you like/have.
If hunting for more, look for PC2-6400, they run slightly cooler than PC2-5300, and are also often cheaper.
They'll still run 'only' at PC2-5300 speed.
MikalE
#5 Post by MikalE » Tue May 22, 2018 7:46 am
I have a T510 with 6GB, only because I needed a 4 GB stick for my T500 to bring it up to 8GB. I took a 2GB stick and installed that in the T510 along with the installed 4GB. Worked fine. Dual channel, single channel, I don't know and don't care as long as it plays music without buffering.
The T510 is only used for streaming music and light internet use.
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
T520 i7 4242-4UU(CTO)
T520: i7-2760QM(2.40GHz),16GB, 500GB SSD/500GB 7200 Drive, 1600x900, 1GB NVIDIA, DVDRW, Smartcard, media card, FPR, Win7 Pro64, whitelist BIOS, N 6300 AGN, German KB, BT 4.0.
Screamer
#6 Post by Screamer » Tue May 22, 2018 8:47 am
There will be an extremely small performance penalty on some video games, but it is only a 1-2 FPS difference at most. This should not affect any other programs, unless they tax your RAM's bandwidth intensively. My guess is that the Northbridge treats half of the 4GB SO-DIMM as a part of the dual channel setup, while the other half of the 4GB SO-DIMM is prioritized differently which might have caused that very slight frame rate drop.
If you were wondering about odd-sized RAM configurations not running in dual channel, here is my screenshot of 1GB + 2GB setup in dual channel. I suggest keeping the 2GB + 4GB configuration, it is not worth to drop 2GB of RAM for the extra 1-2 FPS in certain applications.
hopgarden53
#7 Post by hopgarden53 » Tue May 22, 2018 9:25 am
OK.
Thanks for everyone! :D
