I have a dvd multi burner. Can it burn dvd - RW discs?
I know that it can burn DVD+RW discs and my dvd player can play them, just not sure if it can burn DVD-RW.
DVD + or - RW for dvd burner
IBM Thinkpad T23 1.13 2647-9LU 640MB Ram 40GB hard drive SOLD!
T42 SXGA 1.7 64mb xp
Re: DVD + or - RW for dvd burner
The specs of the burner should give the definitive answer, but it's very rare to find a burner that can burn DVD+ but no DVD- (the other way around was more common at one time).
Since you are posting your question here, in the T6x-subforum, I assume that you are hence making implicit reference to a burner in a T6x ThinkPad. If this assumption is correct, you'll find detailled specs for a couple of the most common T6x multi-burners in the thread FS: Ultrabay Slim DVD-RW burners (R5x/T4x/T6x/X4x/X6x/Z6x).
You may also want to see ThinkWiki (category: T60) which is pointing to Ultrabay Slim Super Multi-Burner Drive.
Johan
Johan
Users browsing this forum: No registered users and 68 guests
