Putting in a new ccfl, and accidentaly tore the bluetooth off of the video cable.
Is this cable still functional as a video/inverter cable?
I guess I should disable the BT driver while I'm at it...
Ok, I found this by ajkula66 somewhere else.
Welcome to the forum!
You actually just need the LCD itself, the cable is shared in T60 series regardless of resolution. As long as you get a proper screen (with a FRU number compatible with T6x series) you'll be fine.
Hope this helps.
George
So it sounds like all t60's share the same cable regardless.
Do all the cables have the bluetooth extension? At least I can do a swap if I really want the bluetooth working.
Double checked. They are two different cables. So still looking for a bluetooth video cable for T60 sxga screen
Tore the Bluetooth off of the SXGA Cable 14" LCD
IBM Thinkpad T23 1.13 2647-9LU 640MB Ram 40GB hard drive SOLD!
T42 SXGA 1.7 64mb xp
- 0 Replies
- 1360 Views
Last post by hall
Mon Jan 15, 2024 2:50 pm
HDMI to USB cable recommendations - please
by ap63 » Wed Mar 13, 2024 5:24 pm » in ThinkPad T60/T61 Series - 5 Replies
- 514 Views
Last post by ap63
Sat Mar 16, 2024 5:40 pm
detachable battery does not charge. White light, then amber, then off.
by redglow » Wed Nov 01, 2023 6:12 pm » in ThinkPad T430-T490 / T530-T590 Series - 2 Replies
- 9870 Views
Last post by redglow
Fri Nov 03, 2023 2:05 am
P14s Losing Power When OFF
by tenplus1 » Sat Dec 16, 2023 5:22 am » in ThinkPad P1/P40/P50/P70 and later Series - 7 Replies
- 1942 Views
Last post by tenplus1
Fri Jan 05, 2024 6:42 am
