ThinkPad T60p Corrupted BIOS- Need Help!
Hi Everyone!
I need help with Corrupted BIOS on T60p. I'm using Phoenix BIOS Crisis Recovery Tool, but I can't get it to work. Every site says that ThinkPad, if Pendrive is detected, should have fan's on 100% or at least Pendrive should flash light. Mine doesn't do that. What am I doing wrong?
I really appreciate any help!
Re: ThinkPad T60p Corrupted BIOS- Need Help!
Did you extract the uncompressed file of the BIOS to the pen drive? The pen drive must be formatted in FAT16 as well, or FAT32 if it doesn't work. You may also need to use the T60's stock BIOS file from Lenovo and not Zender's modified BIOS.
Before you power up your partially functional T60p, you need to hold down Fn+F or Fn+B or Fn+R or Fn+K or Fn+Esc till your pen drive flashes (if it has a status LED). Then you can release your fingers off the keys, it should be doing the re-flashing process. This is assuming that your T60p is not beeping at boot-up, without the pen drive inserted.
EDIT: If I am not wrong, this needs a functional battery and must be connected to the AC adapter. Additionally, I recommend waiting for at least 20 seconds while holding down the key combination.
That's assuming the BIOS is not to far corrupt. If it is too corrupt and will not let you flash BIOS, your best bet is to replace the MB. With a T500 generation or older, I still prefer to flash BIOS from a CD drive.
Okay Guys It's Back and still running. I started swapping RAM Sticks and it started to beep again and automatically started to flash a new BIOS. Even the most broken BIOS from Phoenix it could be reflashed so there is no need to replace MB.
https://imgur.com/a/Vk9DPtJ
That is excellent news!
W520 (C2Q i7-2720QM, 8GB, 60GB SSD)
X61s (2GB, 120GB SSD)
T43p (P M 760, 2GB, IBM Port Replicator II, 128GB SSD)
G41 (P4 3.46GHz, 2GB, 128GB SSD)
Show us image of this memory module that does not work properly?
What memory module now working is what make of memory maker?
Cheers, thinkpadcollection
HELP! I Cant access BIOS menu during windows 11 start
by canonmasta » Mon Dec 04, 2023 5:07 pm » in ThinkPad X230-X280 / X390 Series - 5 Replies
- 3400 Views
Last post by Brad
Sat Dec 16, 2023 6:40 am
Need to repair IBM USB ThinkPad keyboard
by ThinkPad560X » Sun Dec 03, 2023 1:01 am » in Off-Topic Stuff - 0 Replies
- 1808 Views
Last post by ThinkPad560X
Need a Thinkpad recommendation - 2009 Era
by KwikFab » Sat Dec 16, 2023 1:09 am » in Thinkpad - General HARDWARE/SOFTWARE questions - 11 Replies
- 3416 Views
Last post by KwikFab
Wed Dec 20, 2023 5:48 pm
Thinkpad 770 Bios mod for cpu upgrade
by franjimo24 » Sun Dec 10, 2023 8:14 am » in ThinkPad Legacy Hardware - 6 Replies
- 5321 Views
Last post by solidpro
Tue Jan 23, 2024 4:02 pm
