Referring to prior posts regarding my 'broken hinge' viewtopic.php?f=29&t=126795#p821781.
What I found is it is NOT a bad hinge but a cracked backframe of the lcd panel. I am referring to the frame that you see once you remove the top piece of the T61 lid (cover).
The frame is cracked around the area where the hinge is held with 2 pins. I haven't actually removed the hinge yet to determine if the hinge is so tight that it may have caused the crack or if the crack is merely fatigue from the frame being too thin for the flexing stress of opening and closing. Picture https://imgur.com/a/8iDrR3l here.
Should I be looking for a new frame or new assembly that includes LCD (15.4")? My understanding is that parts are no longer manufactured so I presume it would be used. It seems a bit problematic to buy a frame that includes a used screen. I don't even know what parts are easy to obtain. Is there a vendor that someone would recommend?
Need suggestion for broken lcd frame
Re: Need suggestion for broken lcd frame
I'm sure someone around here has a T61 lid without LCD in decent shape and ready to go for not much money. Try posting a WTB (want to buy) ad in the Marketplace and take it from there.
Good luck.
Good luck.
Abused daily: T520, X200s
Thank you, I found a frame on eBay and after soaking my hinges for a week I have it all back together and running.
T60 with corroded structure frame welded to hinges
by Glaurung-quena » Thu Oct 19, 2023 2:09 pm » in ThinkPad T60/T61 Series - 3 Replies
- 3963 Views
Last post by unixed
Fri Oct 27, 2023 10:44 am
W530 Bluetooth sound broken after switching to windows 10
by Gregui To » Sat Dec 09, 2023 6:17 pm » in ThinkPad W530/W540/W541/W550 Series - 1 Replies
- 1701 Views
Last post by mikemex
Wed Feb 21, 2024 12:42 am
Need some advice to choose my new T60
by KadYmz » Sun Nov 19, 2023 2:50 am » in ThinkPad T60/T61 Series - 5 Replies
- 1926 Views
Last post by ZaZ
Thu Nov 23, 2023 5:32 pm
FS: X2100 with need of love and a new home.
by mcfado » Wed Nov 29, 2023 7:29 am » in Marketplace - Forum Members only - 2 Replies
- 1264 Views
Last post by lars-rasmussen
Thu Nov 30, 2023 6:30 am
Users browsing this forum: No registered users and 64 guests
