T60 fails if main battery is present
One of my T60 s suddenly went dead, while plugged into the power supply.
I unplugged it, removed the battery, plugged it back in and it started
normally. I've tried it with another battery with the same result.
Any suggestions?
Thanks.
Chuck
Any suggestions?
Thanks.
Chuck
Re: T60 fails if main battery is present
Had the same, had to replace the mobo.
Hopefully these are very cheap nowadays unless looking for T60p.
(stable under reduction)
I have a bunch of various cheap T60 (and other) motherboards for sale: https://www.theboardroom.info/stock1.html
wujstefan:
Thanks.
RBS:
If I give you the system unit serial no. can you recommend which
motherboard to buy from you?
I've looked for the 'tabook' with the details of my model
but it's not in any of the 'books' that I've found.
The cpu is T7200 but I can't tell what graphics card it has.
Chuck
Thanks.
RBS:
Chuck
S/N lookup for T60 unfortunately is no longer available.
Remove the RAM, underneath you might find a small white label with the motherboard's P/N or FRU.
And if you also remove the keyboard, give us the fan P/N or FRU, so we know at least if you have Intel or ATI.
What does it say in the BIOS (only first 7 characters from SystemUnitSerialNumber) or what 7-char. TYPE on the bottom label?
Thanks again.
I think I have some of what you've asked:
The model no. is 2007-A16, and (using 'discover')
the graphics card is "[AMD] nee ATI Mobility FireGL V5200"
Chuck
Chuck
Caddy speed vs Main drive bay speed
by euless » Wed Nov 15, 2023 11:54 pm » in ThinkPad T430-T490 / T530-T590 Series - 1 Replies
- 1819 Views
Thu Nov 16, 2023 1:26 am
Can you charge a T23/T30/T40 battery in a T60?
by RealBlackStuff » Sat Dec 30, 2023 11:34 am » in Thinkpad - General HARDWARE/SOFTWARE questions - 4 Replies
- 3867 Views
Tue Jan 09, 2024 3:09 pm
T42 Charges and works with the battery in but without battery will not power on.
by kale87 » Fri Oct 27, 2023 3:39 pm » in ThinkPad T40/T41/T42/T43 Series - 0 Replies
- 3167 Views
Last post by kale87
ThinkPad A22m battery recondioning after battery rebuild
by kfzhu1229 » Mon Dec 11, 2023 5:57 pm » in ThinkPad R, A, G and Z Series - 0 Replies
- 2475 Views
