help for a wounded warrior
Some years ago (2012) I bought an already old X31 just to have a backup machine. Nevertheless, in spite of its no tender age, it quickly became my workhorse.
It always run flawlessy, but now strange things happen:
it no longer starts when connected to the mains, but all is ok if you switch it on while running on battery, provided the battery is FULLY charged.
Once started you can reconnect the battery charger and use the X31 the usual way, at least till the next switch off.
Did anyone experience such a strange behaviour ?
Re: help for a wounded warrior
Yes, and more than once.
Defective charging circuit, could be caused by moisture or simply old age. Motherboard swap is the only cure.
Personally, I'd use it "as-is" for as long as it runs.
Your machine, your call.
Abused daily: T520, X200s
Yes I agree with you, even if this X31 is more than a machine to me, almost an (old) friend...
Anyway, I'll try to find a cheap X30/31 on sale for spare parts (maybe I'm lucky).
Cheers
Ggiglio
Cheers
Ggiglio
Shall this be what you are looking for: http://www.ebay.com/itm/Lenovo-IBM-Thin ... 2402786526?
A nice cheap parts machine?
Some switching MOSFET in charging circuit or same charging IC is damaged. You should take it to electronics service, it's quite easy to repair for skilled technician.ggiglio wrote: ↑Sun Oct 08, 2017 4:53 pmit no longer starts when connected to the mains, but all is ok if you switch it on while running on battery, provided the battery is FULLY charged.
T400 With 8GB RAM, undervolted T9600 and Radeon 3470 on Linux Mint and Win10Pro
X41Tablet with 2GB RAM, Pentium M 1.5GHz, mSATA mod with 64GB SSD, Bsel_0 mod
nowadays the only drawback is the extremely low commercial value of X31,that makes the repair undoable, unless you are already familiar with fine electronics (and I am) and have at disposal the mobo schematics (and I don't).
Anyway, I'll keep enjoing the little beast till it's spinning
X31 Schematics
https://elektrotanya.com/ibm_thinkpad_x ... nload.html
Wait until you see: This file is downloadable free of charge: Get Manual
under the picture, then click on Get Manual.
@RBS
thanks (as usual) for showing me where to look for.
As far as I can see figuring out how the charging circuitry works will *not* be an easy task.
But at least I'll end up removing dust from my holy books of electronics
Please help me to choose between T14 and T14s (Gen 4 AMD)
by Inferno » Sat Oct 21, 2023 6:22 pm » in Thinkpad - General HARDWARE/SOFTWARE questions - 1 Replies
- 6145 Views
Last post by mikemex
Mon Dec 11, 2023 10:04 pm
HELP! I Cant access BIOS menu during windows 11 start
by canonmasta » Mon Dec 04, 2023 5:07 pm » in ThinkPad X230-X280 / X390 Series - 5 Replies
- 3396 Views
Last post by Brad
Sat Dec 16, 2023 6:40 am
HELP! My X230 decided not to charge my non-genuine battery.
by canonmasta » Fri Dec 08, 2023 5:31 pm » in ThinkPad X230-X280 / X390 Series - 1 Replies
- 10810 Views
Sat Dec 09, 2023 12:07 am
L14 G1/2 LCD Backcover Replacement Help Needed
by ColdWarrior » Sun Dec 24, 2023 11:51 am » in Thinkpad - General HARDWARE/SOFTWARE questions - 4 Replies
- 2337 Views
Last post by ColdWarrior
Mon Dec 25, 2023 2:36 am
