X61 keyboards
X61 keyboards
I want to buy a replacement keyboard for an X61. Are there different types of keyboard (apart from layout)? I want to make sure that whatever I buy will fit.
And does anyone in the UK have one available?
My ThinkPad Graveyard:
600 * 2, X220, X61 * 2, T61
Re: X61 keyboards
Yes, there are different brands. RBS knows all the brands and which ones are best. Just do some research with the part number and you shpuld get your desired part.
Re: X61 keyboards
I have a 42T3503.
I found this which looks a lot worse for wear:-
http://www.ebay.co.uk/itm/IBM-LENOVO-Th ... 2255469410
In comparison, mine looks almost pristine (after cleaning it ). I guess I could swap the missing keys if it works...
Re: X61 keyboards
2 UK kb models are available Chicony & NMB - I've found the NMB ones best FRU 42T3471.
They are all listed in the HMM linked in forum header.
Home - Win 10 MSi GF63 Gaming Laptop /Arch GNOME 3/X230 Tablet /X61 [Korean] - Debian 10/T60p - Ubuntu 20.10 Helix 2
Work - Win10/Thinkpad X1 Tablet Gen 2
Re: X61 keyboards
You may be surprised - I bought used keyboard for my T500 after breaking original one. Some keys were not in it's place (I assume that this keyboard was assembled with what was laying around) so I though about swapping them in the right position - I was really surprised that they didn't fit in places they should go - the key mechanism was inverted as far as I remember. Fortunately I was able to make frankenkeyboard using both of them. So be aware, that some keys might not fit in correct places.
Re: X61 keyboards
In a T400/T500/W500 you can also put keyboards from the T60/T61.
They are much sturdier than those flimsy pieces of junk.
Why else would they need to also insert those keyboard supports like this?
AFAIK no other Thinkpads needed those!
Here's my info on those:
Looks like there are 4 sets of parts depending on 14" or 15" chasis and whether integrated or hybrid/switchable graphics.
These make use of existing screws and tapped holes in the rollcage for mounting. As such, they can be retrofit to existing systems, but a customer would need to be careful in how these are installed to ensure proper routing of wires, etc.
45N5365 T400 KBD support bracket for Integ model, 2 pieces
45N5366 T400 KBD support bracket for Hybrid model, 2 pieces
45N5367 T/W500 KBD support bracket for Integ model, 2 pieces
45N5368 T/W500 KBD support bracket for Hybrid model, 2 pieces
L40sx and PS/2e M4-1 Space Saver keyboards [Warning: pics]
by ThinkDan » Wed Nov 08, 2023 7:14 pm » in ThinkPad Legacy Hardware - 0 Replies
- 2395 Views
Last post by ThinkDan
Nordic layout of Thinkpad keyboards
by zil » Sat Feb 10, 2024 5:19 am » in Thinkpad - General HARDWARE/SOFTWARE questions - 11 Replies
- 1492 Views
Last post by mikemex
Wed Feb 28, 2024 5:01 pm
[FA][UK & Global] various IBM Space Saver and TrackPoint keyboards [WARNING: PICS]
by ThinkDan » Sun Mar 31, 2024 4:33 pm » in Marketplace - Forum Members only - 2 Replies
- 287 Views
Tue Apr 02, 2024 3:37 am
Wi-Fi card recommendation for X61
by karotlopj » Thu Dec 14, 2023 4:26 am » in Thinkpad X60/X61 Series incl. Tablets - 14 Replies
- 16733 Views
Tue Jan 23, 2024 6:12 am
Users browsing this forum: Bing [Bot] and 11 guests
