X60 tablet screen upgrade to SXGA+
Hi
i've just bought a cheap IBM X60 tablet and have being using it at work for about a week or 2 now, and i'm loving it great little machine.
adding an SSD and a 3gigs of ram has made it great. However the only issue is the screen its 1024x768 now i love the 4:3 aspect ratio but modern programs like office with the ribbon just have no room to see anyting.
so i'm looking at upgrading the screen to the SXGA+ version. I came across this blog
https://ithinkpad.wordpress.com/2011/10/14/x6xipsguide/
and while old it talks about replaceing the x60/1 non tablet screen but more importantly give me a part number HV121P01-101
https://www.ebay.co.uk/itm/SXGA-CCFL-12 ... SwOgdYomKI
now can anyone tell me if this is a good idea will the panel that i linked on ebay be all i need since i have a fully working x60 tablet? is it just a case of taking the lcd out on my x60 and putting all the other parts and cables into the new one?
or will i need to order more stuff?
Thanks everyone
Thanks everyone
Re: X60 tablet screen upgrade to SXGA+
I do not know how safe and good that from ebay
That eBay screen is meant for an X61T.
They are infamous for developing bubbles between surface and LCD.
It will fit in an X60T but those bubbles are gonna spoil it! AVOID!
The bubble free variant that was originally used in the X60t is called HV121P01-100. Most ebay displays of this type come without the front glass, though, so they're not protected for use with the stylus. You'd have to buy a matching 1mm(?) glass to put in front of it.
X62s 3rd batch, [s]T61[/s] T70 14" 4:3 1st batch
You don't need to follow the guide in that blog you linked. That is for installing an X60 Tablet display into an X60 non-tablet machine. Which is a very cumbersome mod. Upgrading your X60 tablet display to SXGA+ is way easier.
T14s | AUO 14" FHD Low Power 400 nit | Ryzen 7 4750u | Windows 10
T70 | 15" UXGA LED with RealBlackStuff LED-Cable-Mod | i7-7700HQ | Windows 10
X62 | 12.1" SXGA+ Xiphmont LED | i7-5500U | Xubuntu / Windows 10
The ideal solution would be to find a fully assembled x60 tablet lcd assembly sxga+ but I can't seem find any.fatpolomanjr wrote: ↑Tue Nov 14, 2017 8:08 pmYou don't need to follow the guide in that blog you linked. That is for installing an X60 Tablet display into an X60 non-tablet machine. Which is a very cumbersome mod. Upgrading your X60 tablet display to SXGA+ is way easier.
Even if you only find the display without the entire assembly, such as here:
https://goo.gl/KbBDWF
the installation is easier than what you see in the blog. You would remove the lcd assembly, remove the bezel, remove the display, place the new display in, and put everything back. No removing and cutting metal frames, plastic tabs, or plexiglass covers. Drop in replacement.
Of course, that is a little bit more involved than swapping lcd assembly, but IMHO it is nothing compared to trying to retro fit an X60 tablet display into a non-tablet X60 or X61.
fatpolomanjr wrote: ↑Wed Nov 15, 2017 7:53 pmEven if you only find the display without the entire assembly, such as here:
Thats more or less what i though. So the only difference would be that there would be no glass on the new panel and the touch screen would no longer work?
X60 tablet sleeve case / shoulder bags on eBay UK
by ThinkDan » Sun Nov 05, 2023 5:44 pm » in Thinkpad X60/X61 Series incl. Tablets - 0 Replies
- 1763 Views
Last post by ThinkDan
- 0 Replies
- 2069 Views
Sun Oct 22, 2023 8:33 am
[Free FS] 755CSE Screen Damaged (Screen Only)
by clamic235 » Thu Feb 08, 2024 3:24 am » in Marketplace - Forum Members only - 0 Replies
- 418 Views
Last post by clamic235
701c screen distortion- gpu or screen failure??
by nicefisher » Fri Feb 16, 2024 12:50 pm » in ThinkPad Legacy Hardware - 3 Replies
- 681 Views
Last post by astral
Wed Feb 21, 2024 11:07 am
