Booting from an SD card on X61 tablet
portsample
#1 Post by portsample » Sat Dec 09, 2017 2:04 pm
I am interested in booting my newly acquired X61 tablet from an SD card. I can see the card (I've put a Linux OS on it) when booting from the hard drive, But can't get the BIOS to boot from the card. I have not updated the BIOS: it is 1.20 (7SET34WW), 7/29/2008. Thoughts on this? Would Middleton BIOS allow booting from the SD card? Thanks in advance.
T61, 14.1", X9000 2.8ghz, Intel GM965, 8gb RAM, 250gb SSD, 1tb SATA Ubay, openSuse 42.3/Win8
(2) T61, 14.1", T9500 2.6ghz, Intel GM965, 4gb RAM, 250gb SSD, openSuse 42.3/Win8 (spares)
Re: Booting from an SD card on X61 tablet
#2 Post by axur-delmeria » Sat Dec 09, 2017 3:28 pm
No it won't.
The only bootable SD card readers I know are USB-based, making use of the BIOS's USB boot routines
Toy: X60F Core Solo U1300
:cry:
TPFanatic
#3 Post by TPFanatic » Sat Dec 09, 2017 5:42 pm
BIOS won't see the SD as a bootable device, and neither will Windows. Linux could probably boot it but it first has to boot from a BIOS-accepted bootable device, HDD or USB.
lenovo X230 i5 3320m IPS 8GB
lenovo T430 i5 3320m FHD 8GB
lenovo T500 P9700 WUXGA 8GB
Enable 2 finger scroll on any Synaptics touchpads with registry: http://forum.thinkpads.com/viewtopic.php?f=2&t=122612
MisterB
#4 Post by MisterB » Sat Dec 09, 2017 6:40 pm
The X201 Tablet will boot from an SD card. It is the only Thinkpad I know of that will. It sees the SD card in the BIOS as a USB drive. On mine, I have Linux Mint 17.2 on a 64gb SDXC card. I've partitioned it with 32gb as a fat 32 partition and a 24gb system and 8gb swap partition. If the fat 32 partition is done first, Windows will see it as a smaller fat 32 card while Linux can see the whole card. It is a bit faster than a USB 2.0 drive but still not all that fast.
The W700 will boot from a CF card but not the W701. Neither will boot from an SD card.
Currently using: A W500, a W520, two X201Ts, an X220T, an X61T, a 14" T60P, a 15" UXGA T60P, and a W701.
Currently idle: A spare W500, a spare X61T, a 14" T61, a 15" SXGA+ T60, a 14" T60, and my first Thinkpad, a 770X.
portsample
#5 Post by portsample » Sat Dec 09, 2017 7:31 pm
Perfect. Thanks for the spot on answer and explanations. This is a new machine for me. Still trying to figure it out.
flyingfishfinger
#6 Post by flyingfishfinger » Sun Dec 10, 2017 1:14 pm
If you're really into hacking, the Plop bootloader can be installed as a PCI option ROM. That should let you load a Linux kernel from wherever, probably including an SD card.
R
