Succefully upgraded X61 with X41t screen
X60/X61 and X60t/X61t Series
maxcreations
#1 Post by maxcreations » Mon Feb 22, 2021 6:03 pm
Just wanted to say, that I was able to place x41 tablet XGA LCD on x61 thinkpad.
Frame from x41 was to thick, so I dissasembled both screens and placed X41's LCD to the x61's frame with backlit. Also I cutted several clips on the top of the x61's white plastic frame to fit it under metal frame.
To connect x41t screen I used cable from aliexpress.
Here are the pictures of completed work.
Issues: I "lost" initial x61 LCD since it's totally not fits x41t frame without more plastic-cutting-actions; also got some backlit spots on the left side of the new screen (not too annoying, but still), so someday I will need to return to fix this.
Now I'm thinking about doing this one more time but with x31.
I will be here from time to time, so if you got any questions — feel free to ask.
560Z, x31, X41, X61 IPS mod, x13 4750u
Re: Succefully upgaded X61 with X41t screen
#2 Post by axur-delmeria » Tue Feb 23, 2021 12:11 am
Congrats! You're probably the first one I've encountered online who's done this mod.
Can you mention the exact LCD brand/model of the X41 Tablet screen used in your mod?
Backup: X601 Core 2 Duo T8100
Toy: X60F Core Solo U1300
:cry:
maxcreations
#3 Post by maxcreations » Tue Feb 23, 2021 7:00 am
x41t's panel was HT12x21-351 and x61's LTN121XJ-L07.
Also, while I was experimenting with this X61 laptop yesterday (based on this topic) I was able to undervolt the T7300 CPU to these values:
1 == 6.0x == 0.8500V
2 == 7.0x == 0.8500V
3 == 8.0x == 0.8875V
4 == 9.0x == 0.9375V
5 == 10.0x == 0.9875V
Runs fine so far. Huge temperature reduction. While typing this post, with 2 tabs opened in Google Chrome, temp is ~43C. Under the load goes up to 70C, but not 90 as it was.
Nostos92
Re: Succefully upgraded X61 with X41t screen
#4 Post by Nostos92 » Sun Mar 07, 2021 2:26 pm
Just to clarify, did you use both the x61's frame and backlight, or just the frame?
maxcreations
#5 Post by maxcreations » Mon Apr 19, 2021 7:56 am
Hello! I used x61’s white plastic frame with x61’s backlight and x61’s metal frame. Only LCD from x41t.
zoltan87
#6 Post by zoltan87 » Tue Jun 01, 2021 3:37 pm
Did you buy that exact cable from Aliexpress? It says its a cable for the 1400 x 1050 panel. i was under the impression that the XGS panels would need a different cable, was I wrong?
I have an X41 tablet for this exact reason, I wanted to use its nice IPS screen, and transplant it into either my X32 or X61 laptop, but I have been sitting on this project ever since (story of my life...).
Thinkpad T60, 15" Flexview, with mods (Xiphmont's LED mod, T500 heatsink, cpu undervolt, reinforced frame)
Thinkpad T601, 15" Flexview, with mods (Xiphmont's LED mod, T500 heatsink, cpu undervolt, reinforced frame)
Thinkpad X32
Thinkpad T22
NEC ProSpeed SX/20
Arc
#7 Post by Arc » Thu Jun 17, 2021 8:55 pm
I also bought the cable from that seller on Aliexpress, if I recall the mod cable is needed for swapping in the Flexview screens from X41t/X60t/X61t because they have a different pinout than the non-tablet panels. Should work just as well with the XGA panels as it does the SXGA+ panels.
Lenowo [ X41t | X61t SXGA+ | X61s SXGA+ | W500 | X301 | X201 with USB-C PD | X201t | T430 Hackintosh | W530 ]
ThiccPads 「 600 | 700Z | A21m | X22 | A31p | R52 」
[ Lifebook U810 | P1620 | P1630 ] [ iBook G3 Snow ] [ XPS M1710 ]
Many others have come and gone!
Return to “Thinkpad X60/X61 Series incl. Tablets”
