So after having the new panel at home for a year, i mustered the courage to dive into the modification of my X61. As i have tried it in the past (and failed - mainly due to the wrong tools at hand at the time) i was super careful and light on the touch this time, using a dremel to remove the ears.
I researched many guides (of course) before starting it make absolutely sure that i would get the best results. When i did this modification (remember i was super careful) i took off the metal frame and made it a "U" and carefully taped the top to not let through light that way (and to be able to close the bezel properly). In the end, It actually came out quite nice - with two open questions
1. whenever i have the machine powered on with the power-brick connected, i sometimes see som minor "lines" flashing on the screen. Not always, but sometimes. When i pull the power-plug and run only on batteries, everything is perfect without any lines at all. I have a couple of different power-bricks (both 65w and 90w) that i have tried to alter between but it does not matter.
2. What is the trick to snap on the top part of the bezel properly? right now, on the top-left side there is this gap that i can't get snapped shut.
Thinkpad X61 with sxga+ mod - slightly flashing "lines"
W530 3940xm/32gb/520/240/240gb ssd, FHD
T410 w. I7-640m, 8GB, 240+128gb ssd hd, 1440x900
X61 w. T7500, 8GB, 240gb ssd, 1400x1050
760E
380ed
365xd
360cs
701cs
T21
T590 (work machine)
760E
380ed
365xd
360cs
701cs
T21
T590 (work machine)
Re: Thinkpad X61 with sxga+ mod - slightly flashing "lines"
Just wanted to follow up on this. It is now fixed.
The issue was apparently the adapter cable that i used previously (which seemed to be causing this odd flicker). I bought it a long time ago (from a member here i believe).
Not wanting to give up on the new screen, i ordered a new cable from Aliexpress (Kevins trade shop) and installed it and now the screen is 100% perfect.
https://www.aliexpress.com/item/3268563 ... 81b0kk5o2j
https://i.ibb.co/q16sCH8/X61.jpg
FORUM warning:
picture(s) WAY too big, tags removed. Please read the Forum Rules, especially Section 5: viewtopic.php?f=16&t=14339
FORUM warning:
760E
380ed
365xd
360cs
701cs
T21
T590 (work machine)
760E
380ed
365xd
360cs
701cs
T21
T590 (work machine)
Thinkpad 770 Bios mod for cpu upgrade
by franjimo24 » Sun Dec 10, 2023 8:14 am » in ThinkPad Legacy Hardware - 6 Replies
- 4980 Views
Last post by solidpro
Tue Jan 23, 2024 4:02 pm
t400 lcd mod/upgrade possible?
by astral » Sun Oct 01, 2023 5:36 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 6 Replies
- 3290 Views
Last post by astral
Mon Oct 02, 2023 9:22 am
Anyone here attempt the X61HK mod?
by filipinogamer21 » Wed Nov 08, 2023 6:21 pm » in 51nb and other modded Thinkpads - 4 Replies
- 1859 Views
Tue Nov 14, 2023 6:37 am
T60 - How would I do an LED mod?
by connect5 » Mon Nov 27, 2023 4:11 pm » in ThinkPad T60/T61 Series - 9 Replies
- 3726 Views
Wed Dec 27, 2023 3:28 am
Users browsing this forum: Bing [Bot] and 45 guests
