Verifying VT-x (Intel virtualisation technology)
maja_ldm
#1 Post by maja_ldm » Thu Jul 13, 2017 1:09 am
I have a X201 with the i5 M560 and I need to use the AVD emulator of Android Studio which requires VT-x virtualisation to be activated. I checked the BIOS and Intel TXT and Intel AMT are both disabled, virtualisation and VM-d are both enabled, but Android Studio keeps reporting that VT-x is not activated (as a general check I could launch a Virtual Box machine).
How can I check if VT-x is indeed enabled on my laptop?
Re: Verifying VT-x (Intel virtualisation technology)
#2 Post by RealBlackStuff » Thu Jul 13, 2017 5:43 am
Welcome to the Forum.
Check in your BIOS/Security if you have a Virtualization option.
If not, you can't use VT-x.
jdrou
#3 Post by jdrou » Thu Jul 13, 2017 5:06 pm
If running Windows 8 Pro or later you may also need to disable Hyper-V.
Current Thinkpads:
maja_ldm
#4 Post by maja_ldm » Fri Jul 14, 2017 6:41 pm
In the BIOS I have Virtualization and VT-d, both are enabled.
I use Windows 10 Pro, Hyper-V is disabled.
