LVDS 13.3 FHD IPS screen 90% color gamut
harryK
#1 Post by harryK » Thu Jul 27, 2017 10:58 am
This Taobao seller (https://2.taobao.com/item.htm?id=555910282478) offers a modded X230 with a 13.3" FHD screen that uses the LVDS interface, apparently with 90% NTSC coverage. The panel must be this one: http://www.panelook.com/LQ133M1LW01_SHA ... 24644.html
It uses 2 lvds channels, whereas afaik the X230 only supports one, so some sort of modification must still be needed. I was thinking of ordering it, at least to look at how it's made, but then I noticed that the screen's power consumption is rated 17W!
boutch55555
Re: LVDS 13.3 FHD IPS screen 90% color gamut
#2 Post by boutch55555 » Tue Aug 01, 2017 3:54 pm
Not possible on a x230. Auto translate on chrome got me "lvds crack", perhaps a patch to enable backlight control without screen mirroring. The MSATA3 mention points to this laptop that uses a LQ133M1JW11 probably confirmed by the w11 mention in the description.
harryK
#3 Post by harryK » Thu Aug 03, 2017 3:18 pm
I interpreted it as "lvds, crack white list", as the only screen with "99%" color gamut (90% actually) is the one I linked, and it's LVDS.
RMSMajestic
#4 Post by RMSMajestic » Thu Aug 03, 2017 3:58 pm
He used the DP port from the dock. converted to a dual ch LVDS. There might be some compatibility problem with the system when using multiple screens
boutch55555
#5 Post by boutch55555 » Fri Aug 04, 2017 5:02 am
But the LQ133M1LW01 has a 319.9 × 189.3 outline, there is absolutely no way it can fit a x220/x230...
I don't know why they would convert the DP from the dock to lvds since there are good edp panels already, but it's probably possible.
Also, the most recent Sharp panels (like the W11 I mentionned) aren't listed on panelook, so it's hard to get the specs or list available panels for those. They made a W02 of the panel you mentioned according to this pdf but it's still 310.6mm wide, won't fit.
Users browsing this forum: xash and 5 guests
