LP125WH2-SLT2 high pitch noise and random flickering
alisan
#1 Post by alisan » Sun Oct 15, 2017 2:29 am
Hello all,
I get my hand on a LP125WH2-SLT2 IPS screen with right and left mounting holes, (edid says it is a LP125WH2-SLT2). The screen is wonderful, colors are awesome and I feel that it is way easier to my eyes than LP125WH2-SLB3 and LP125WH2-SLT1...
Unfortunately it has some serious problems.
1) The screen emits high pitch noise coming from around the LVDS connector on the screen (that significantly increases on white background).
2) The screen also occasionally tears/flickers, it happens randomly, like every 5/10 minutes or so.
The screen has been tested on a x220. The connector is fine as the LP125WH2-SLB3 works without any problem.
Do you think there is a anything can be done to fix it?
