The charging port on my X230 is becoming loose. I could replace it, but with my usual daily procedure of taking the laptop out and around for the day and only coming back home to charge it (I never carry around my charger, and I always charge the computer at the same spot on my desk) I was instead considering buying a compatible slice battery and using it as a 'charging pad' through the dock connector.
Since I won't actually be making any use of the battery cells inside the slice, I don't need or want to buy a new one or even a reasonably-well-condition one from Ebay. I just need a shell, a working power socket, connector and PCB. So I ask, does anyone here have an old depleted X220/X230-compatible slice battery that they're not using anymore? I will pay $10 and shipping to get it off your hands. Preferably from US to keep shipping cost reasonable, I don't want to pay more than maybe $25 total. DM please. Thanks.
Anyone with a spent X220 Slice Battery 19+?
IBM ThinkPad X41 Tablet ... formerly: T23, T43
lenovo ThinkPads X200, X300, X300, X301, X220, X230 FHD Classic ... formerly: T420, W520, T430
HP G62
Toshiba Portégé R930
Desktop: i7-4770K + R9 290X
HP G62
Re: Anyone with a spent X220 Slice Battery 19+?
Why not get an Ultrabase. It is a battery but with extra ports, a DVD drive, and your charging port.
http://www.ebay.com/itm/04W6846-x220-x2 ... SwxbtZpu9j
This 40Y7629 external charger will also do the trick and in your budget: http://www.ebay.com/itm/282677183712
Remove your battery and plug it onto the cable of that charger.
Plug your power-supply into the charger and off you go.
This one has some better pictures: http://www.ebay.com/itm/152746233634
See also viewtopic.php?p=680106#p680106 for an extra battery extension cord.
Thank you! I did not realize these go for so cheap. I ordered one.Thinkpad4by3 wrote: ↑Mon Oct 16, 2017 8:09 pmWhy not get an Ultrabase. It is a battery but with extra ports, a DVD drive, and your charging port.
HP G62
HP G62
X220 Battery Recelling
by N4b00 » Thu Dec 28, 2023 5:56 am » in ThinkPad X200/X201/X220 and X300/X301 Series - 9 Replies
- 3038 Views
Sat Mar 23, 2024 12:06 pm
Farewell to my X220...
by axur-delmeria » Tue Nov 28, 2023 12:15 am » in ThinkPad X200/X201/X220 and X300/X301 Series - 5 Replies
- 18092 Views
Last post by mikemex
Wed Jan 10, 2024 5:32 pm
Thinkpad X220 the webcam doesn't work but the thinklight does!!
by ned91 » Sat Dec 23, 2023 12:28 pm » in ThinkPad X200/X201/X220 and X300/X301 Series - 1 Replies
- 3959 Views
Last post by nomad1977
Sat Dec 23, 2023 6:33 pm
Thinkpad X220 Tablet Step-By-Step Windows 11 with all Fn key
by nomad1977 » Sat Dec 23, 2023 5:32 pm » in ThinkPad X200/X201/X220 and X300/X301 Series - 3 Replies
- 5497 Views
Sun Dec 24, 2023 5:01 pm
Users browsing this forum: Bing [Bot] and 33 guests
