Hello all thinkpaders!
I'm thinking of purchasing a X230 tablet but the only thing that's stopping me is that I'm not sure if one can swap the keyboard of it with the one from its older brother the X220 tablet.
Also do you think that there is a point in buying the x230t in the first place even if it is possible to change its keyboard when one can simply buy a x220t. Is the performance of the x230t that much better than the x220t or are they more or less the same.
The versions I'm theoretically comparing are the ones with intel i7.
I would like to hear what you guys and girls Think.
Thank you all in advance.
X230 tablet classic (X220t) keyboard swap. Possible?!?!
Re: X230 tablet classic (X220t) keyboard swap. Possible?!?!
Yes, I believe you can swap the keyboards and apply the embedded controller patch. I know it possible on T/W/X*30 systems and I don't see why the tablet would be different.
CPU performance-wise, for similar clock speeds, there will not be a big difference. The following difference may be more significant:
* Better GPU performance
* Support for 3 screens in extended desktop modes (versus 2 on *20 series)
* USB 3.0 (unlike the regular X220, the X220 Tablet has no USB 3.0 even in the i7 version)
P1 5th gen - Swapping keyboard with WWan antenna for keyboard without Wwan. Possible?
by Phidelio » Mon Jan 15, 2024 9:21 am » in ThinkPad P1/P40/P50/P70 and later Series - 1 Replies
- 2139 Views
Last post by H-Atkinson
Fri Jan 19, 2024 2:56 pm
Classic ThinkPads installed in IBM System/390 and zSeries mainframes
by ThinkDan » Mon Nov 27, 2023 4:39 pm » in ThinkPad Legacy Hardware - 13 Replies
- 4477 Views
Last post by ThinkDan
Fri Feb 02, 2024 4:18 am
T580 Compared to Classic Thinkpads and Macbook Pro
by MisterB » Fri Mar 15, 2024 12:51 pm » in ThinkPad T430-T490 / T530-T590 Series - 0 Replies
- 247 Views
Last post by MisterB
- 1 Replies
- 1815 Views
Last post by TPFanatic
Tue Nov 21, 2023 9:31 am
Users browsing this forum: No registered users and 36 guests
