X201 hangs in BIOS, slow POST
TPFanatic
#1 Post by TPFanatic » Sun Dec 10, 2017 11:10 am
POST takes around 2 minutes to get to Thinkpad screen, then another 2 minutes to start loading an OS at which point the lappy functions completely as normal.
I can get into the BIOS but pressing enter on "Config" results in another long hang followed by no response from the keyboard (onboard or USB) so I can't do anything in there.
I could get into the "Security" settings and can toggle disabling / enabling the Security Chip, if that's contributing to the issue here.
I want to get to disable Intel AMT but that's under "Config".
Already tried reflashing the Lenovo BIOS to no effect.
When I last put this laptop away it was throwing the NVRAM Storage Full errors which no one has a solution for. At least it can boot again, somehow. Any hope of resuscitating this? :??:
Home theater: lenovo T420
Re: X201 hangs in BIOS, slow POST
#2 Post by RealBlackStuff » Sun Dec 10, 2017 11:17 am
Have you tried a fresh new HD/SSD?
TPFanatic
#3 Post by TPFanatic » Sun Dec 10, 2017 11:30 am
Yes. With or without a drive the POSTing issues persist. There's actually very little IO plugged in, just the lid, keyboard, CMOS batt, and fan. When I do put in a Windows drive or Ubuntu USB they will eventually boot after 5 minutes of POSTing. I'm unable to modify any settings under "Config" in the BIOS.
Seems there's a common underlying issue in Arrandale Thinkpads.
https://forums.lenovo.com/t5/forums/v3_ ... 041/page/1
https://forums.lenovo.com/t5/ThinkPad-T ... -p/1760537
It's related to the [censored] Intel AMT backdoor.
https://forums.lenovo.com/t5/ThinkPad-X ... d-p/811249
Disabling Intel AMT in the BIOS wrecks the BIOS.
Since I can boot Windows I'll see what I can do about updating Intel AMT firmware, but if it's already disabled in the BIOS there's probably no saving it....
edit:
This Intel ME 6.2 firmware update refuses to work, says it can't communicate with the ME chip. Figures. In Device Manager the Intel ME Interface has the caution symbol and properties shows "Code 10".
Open source BIOS is probably the only way out of this. I don't have an external flasher or the IT knowledge of how to use one, tho.
Geartooth
#4 Post by Geartooth » Fri Dec 15, 2017 8:39 am
I had the same Late POSTing with my X200. Unplug the CMOS and wait a while. I waited 20 mins and restarted it. It booted up fine, albeit with BIOS version 1.01. Reflash the BIOS and it should work.
Trash Picked X200, 4GB w/ 500 GB HDD dug out of Drawer
jaspen-meyer
#5 Post by jaspen-meyer » Fri Dec 15, 2017 11:40 pm
I was thinking the same thing: remove cmos, hold power button for 10 seconds, restart.
As far as I know opensource bios won't work on that board. You can pick up a broken machine on ebay and use its mb.
T420 i7 3612QM; T420 i7 3630QM; T400 Q9100; x60s libreboot, led; x24 xiphmont led
shawross
#6 Post by shawross » Sat Dec 16, 2017 1:35 am
The Arandale in the X201 is susceptible to ME problems and maybe this was because it was the first generation with the newer ME.
If I enable mine in the BIOS I get the 4 or 5 beeps which repeats. I seem to get a slight battery drain when my laptop is shutdown and I don't know if this is attributable to the ME.
Although I was able to update the firmware for the recent backdoor exploit and and then I disabled in BIOS and my system boots fine . I ran the Intel Detection software and mine came back as fixed which is good.
For your issue disabling ME just sets it back to default settings and this does nothing other than clear settings.
I would update your ME drivers and see if you can get into the ME software and see what is going on. Maybe you could update your BIOS and I assume you have reset your embedded controller.
Goodluck
Active --- Love the X series
X301 SU9400 IDA Mod - W 7 / X201 540M - W 7 / X220 2520 - W7
Nostalgia
X61 T7500 / T43's / T42
alisan
#7 Post by alisan » Mon Dec 18, 2017 1:27 pm
I have the same problem on a x200s. The driver fails in Linux to communicate to ME, tried also a windows setup, same thing, driver fails.
I tried to remove the cmos battery, but not for 20 minutes, just for few minutes, same problem. I'll try again to remove the cmos battery for longer time, when I get back home from my long trip.
#8 Post by dr_st » Wed Dec 20, 2017 11:45 am
This certainly seems like a bug in the ME-BIOS communication on Arrandale machines. Something in the BIOS does not respond properly when ME is disabled.
I recently tried to disable ME on my T410 (through the Ctrl+P menu), and the slow POST (15-20 seconds) + long hang in BIOS config menu (~2 minutes) started happening. Once I re-enabled ME in the Ctrl+P menu, both problems went away.
Current: Thinkpad 25 (20K7), Yoga 14 (20FY), X220 4291-4BG, T410 2537-R46, T60 2007-QPG, T42 2373-F7G
Retired: X61 7673-V2V, T60 1952-F76, A31p w/ Ultrabay Numpad
Users browsing this forum: x3kcl and 4 guests
