X220T was flashed with non tablet bios
derick
#1 Post by derick » Mon Dec 25, 2017 5:22 pm
Hello, after mistake, I flash non tablet bios 1.43 into X220T and my tablet is not working as tablet anymore. (Work as x220 laptop only). I think, EC controller was flashed with wrong non tablet FW. How I can reflash it back, to tablet version? Thanks for answers.
in use: T520, T431s, X230T, x61s (pinmod), x200s, x300 (pinmod), X220T
Past: 380x 600e, 240x, A22m, T20, x30, T30, T40, x41, x41T, T60, T61, T400, T500, R500, x60s, x61, x200T, x201T, T420, T430, X230i, X220i
TPFanatic
Re: X220T was flashed with non tablet bios
#2 Post by TPFanatic » Mon Dec 25, 2017 5:24 pm
The way you went one way should work the other way, I would think.
If the Lenovo flasher won't do it, try Winphlash. Sometimes it is bundled together with the Lenovo files.
lenovo X230 i5 3320m IPS 8GB
lenovo T430 i5 3320m FHD 8GB
lenovo T430s i5 3230m QHD 8GB
lenovo T500 P9700 WUXGA 8GB
Enable 2 finger scroll on any Synaptics touchpads with registry: http://forum.thinkpads.com/viewtopic.php?f=2&t=122612
derick
#3 Post by derick » Mon Dec 25, 2017 5:29 pm
I tried it. I reflash Bios back to 1.37 version, but controller was not changed. Also FL2 file only was flashed, but no success.
#4 Post by RealBlackStuff » Tue Dec 26, 2017 3:08 am
If it lets you, flash to an older version BIOS with different EC.
Then reflash with the proper 'new' BIOS/EC.
derick
#5 Post by derick » Tue Dec 26, 2017 5:31 am
This version 1.37 has older EC FW (1.23). I look to bios file and Lenovo says (in readme), that Bios for x220 and X220T is the same.
derick
#6 Post by derick » Tue Dec 26, 2017 8:11 am
I sucessfully do it under linux and this website:
https://workaround.org/article/updating ... ash-stick/
Thanks for help.
