I've recently got a cheap (very cheap in fact), great looking X201 for my friends' mother.
The thing is, as far as I recall these systems ran pretty hot due to standard 35W TDP CPUs, and with turbo boost. This particular one has a i5-520.
Hitting 100C under synthetic load is still very high IMO. Using orthos, stressing both cores up to turbo boost results in 100C after 2-3 mins.
With light load the system keeps 60C w/ fan at 1 via tpfancontrol and eats around 17W. Light load = typing this message; CPU multiplier on battery is reduced to 15x (~2GHz), LCD brightness 9/15.
Isn't it running way too hot, eating way too much battery? I can't see the CPU being loaded using allcpumeter, and after orthos the system gets back from 100C to constant 60c in 5secs, so I don't expect the cooling system to be faulty.
X201 running hot, eating LOTS of power
(stable under reduction)
Re: X201 running hot, eating LOTS of power
They can run hot but yours seems very hot for some reason. I would make sure the bios is set to adaptive for the CPU.
I have this on mine and it still has enough power when I need it. Maybe a clean and a thermal repaste might be in order.
Active --- Love the X series
X301 W 7/Mint | X201 540M L Mint | X220 2520 W7/Mint
Nostalgia
X61 T7500 / T41 T42 T43 / A31
Nostalgia
Seconded. Spreading, then scraping off excess paste with a credit card seems to help with applying the optimal amount.
ThinkPad T530 Very little power, Will not power on
by ThinkPad560X » Sun Mar 10, 2024 12:42 am » in ThinkPad T430-T490 / T530-T590 Series - 2 Replies
- 361 Views
Last post by ThinkPad560X
Sun Mar 10, 2024 12:57 pm
x201/x200 fanatic - host of issues, thermal pasting with PTM7950 etc
by xannnnnayz » Sat Nov 25, 2023 7:54 am » in ThinkPad X200/X201/X220 and X300/X301 Series - 0 Replies
- 2766 Views
Last post by xannnnnayz
T42 Charges and works with the battery in but without battery will not power on.
by kale87 » Fri Oct 27, 2023 3:39 pm » in ThinkPad T40/T41/T42/T43 Series - 0 Replies
- 3162 Views
Last post by kale87
ThinkPad T460 refuses to stay on after power button is pressed
by Fropple! » Fri Dec 08, 2023 1:31 am » in ThinkPad T430-T490 / T530-T590 Series - 0 Replies
- 7471 Views
Last post by Fropple!
