x220t fhd mod?
TheForgottenKing
x220t fhd mod?
#1 Post by TheForgottenKing » Fri Apr 13, 2018 11:46 am
I can think about two ways of doing this, one easier than the other
First way would be a nitrocaster mod combined with a fhd digitizer, but I cannot for the life of me find a compatable screen
Second way: modify the screen and attach this: https://www.amazon.com/dp/B00XK5A502 to the top of the laptop and go from there
Any ideas? My x220t has ghosting so I want to get to work on this if possible
LINKS TO POSSIBLE SCREENS:
https://www.ebay.com/i/162993505999
https://www.bonanza.com/listings/236097378
Re: x220t fhd mod?
#2 Post by axur-delmeria » Fri Apr 13, 2018 11:53 am
IIRC Nitrocaster's FHD kit won't fit in an X220T.
Toy: X60F Core Solo U1300
:cry:
TheForgottenKing
Re: x220t fhd mod?
#3 Post by TheForgottenKing » Fri Apr 13, 2018 1:27 pm
I have read that it works but with traditional displays, no touch capabilities
Re: x220t fhd mod?
#4 Post by axur-delmeria » Fri Apr 13, 2018 1:52 pm
On the very first post on Nitrocaster's thread https://forum.thinkpads.com/viewtopic.p ... 40#p792251, there's this part:
Q: Does this mod support X220T/X230T?
A: No. It's technically possible to design special version of the adapter board that would fit in tablet, but then you'll need to replace the screen. Which, again, is technically possible, but not really doable.
I don't know if the circumstances have changed since then.
:cry:
TheForgottenKing
Re: x220t fhd mod?
#5 Post by TheForgottenKing » Fri Apr 13, 2018 8:51 pm
What a shame
What is the max resolution for single channel LVDS? And is the x220t single channel? I would presume so
wojtekS
Re: x220t fhd mod?
#6 Post by wojtekS » Sat Apr 14, 2018 1:16 am
A single-channel LVDS cable has just enough bandwidth to support 1366x768 @60Hz.
Yes it is.
Re: x220t fhd mod?
#7 Post by axur-delmeria » Sat Apr 14, 2018 7:10 am
Yes it is.
The highest resolution I've seen on a single-channel LVDS is 1400x1050 on the X60T/X61T. Also notable is the 1440x900 screen on the X200.
:cry:
wojtekS
Re: x220t fhd mod?
#8 Post by wojtekS » Sat Apr 14, 2018 9:43 am
Yes but we are talking about X220 / X230.
You will not fit a T60/T61 panel in X220 / X230 shell.
Re: x220t fhd mod?
#9 Post by axur-delmeria » Sat Apr 14, 2018 10:47 am
I don't know where you got the T60/61, but I specifically mentioned X60T/61T, AKA X60 / X61 Tablet.
But you're right, it won't fit in the X220 chassis.
I was under the impression that the question was about single-channel LVDS in general, and not specific to the X220/230 family.
:cry:
TheForgottenKing
Re: x220t fhd mod?
#10 Post by TheForgottenKing » Sat Apr 14, 2018 9:49 pm
I might look into fitting a 1400x1050 or 1400x900 screen into the x220t, it would take a modification to the case but who cares :D
Anyone got any touchscreen displays for sale?
Thinkpad4by3
Re: x220t fhd mod?
#11 Post by Thinkpad4by3 » Sat Apr 14, 2018 9:54 pm
1440x900 will fit without an issue, it is much 0.4" smaller and should work just fine as long as the pins match. The 1400x1050 is RARE as all get out and would require a HUGE HUGE HUGE overhaul. Don't do that. :BAAAD!:
TheForgottenKing
Re: x220t fhd mod?
#12 Post by TheForgottenKing » Sat Apr 14, 2018 9:55 pm
True, and the x61t is only 1024x768
Now the problem is I want touch functionality. Is there any screen with 1440x900 touch?
TheForgottenKing
Re: x220t fhd mod?
#13 Post by TheForgottenKing » Sat Apr 14, 2018 10:03 pm
Bad Idea Removed
