X220 gpu pad
X220 gpu pad
Hi, my x220 didn't want to start because of a fan error. I've removed the keyboard and saw that it spins for a second in on start and then stops. When I disassembled the laptop to clean it I've noticed that it is moving very hard and decided to rejplace it. When I was cleaning the heatsink I removed the gpu (I assume) thermal pad. Is it ok to replace it with thermal paste or better source a pad. Also I disconnected the bios battery by mistake should I expect any issues with this. Sorry if it has been discussed but I'm forced to use tablet now and I'm too old for this touch stuff
Re: X220 gpu pad
It's not the GPU. The Intel HD 3000 graphics in the X220 is part of the processor itself. What you're looking at is the Platform Controller Hub (PCH) which is the equivalent of the southbridge chip. It handles the USB and SATA ports, as well as the PCIe x1 links for the WiFi card and the Expresscard slot.
And no, you cannot use paste alone, as the gap is too big. You need a thermal pad, I think 15mm x 15mm with 1mm thickness is enough.
Re: X220 gpu pad
Thanks a lot. I'll have time to find it untill my new fan arrive.
P.s. yes I remember southbridge that's how old I am .
Can you add a GeForce GPU in a G41 with Intel GPU?
by Gonzaleitor » Thu Oct 26, 2023 1:51 pm » in ThinkPad R, A, G and Z Series - 2 Replies
- 5536 Views
Last post by Gonzaleitor
Thu Oct 26, 2023 5:22 pm
Thermal Pad - (Thickness)
by norrinraddhr » Thu Mar 07, 2024 4:25 am » in Thinkpad X60/X61 Series incl. Tablets - 4 Replies
- 912 Views
Last post by norrinraddhr
Fri Mar 08, 2024 8:25 am
- 4 Replies
- 5293 Views
Last post by marttt
Mon Jan 15, 2024 2:15 am
701c screen distortion- gpu or screen failure??
by nicefisher » Fri Feb 16, 2024 12:50 pm » in ThinkPad Legacy Hardware - 3 Replies
- 920 Views
Last post by astral
Wed Feb 21, 2024 11:07 am
