[FAN FOUND] T520 what is the best heatsink that will work well with an i7 2960xm and fit in a T520 integrated graphics.
I have had this laptop for a few months now. I am planning to upgrade the processor. I'm really just looking for a fan/heatsink to combat it's insane heat. Is there even a powerful enough fan, if so will it withstand OC for longer amounts of time. Even 24 hours. Help.
To all who have read my request and those who will read this will this be sufficient http://m.ebay.com/itm/262933210164?_mwBanner=1
Re: [FAN FOUND] T520 what is the best heatsink that will work well with an i7 2960xm and fit in a T520 integrated graphi
Are you sure?
That 75Y5774 is a fan for the first X1 (non-Carbon).
You've been ripped off by a seller who doesn't know his stuff!
Look at the CPU screw holes distance/locations if you don't believe me.
That's an eBay case for "not as described" and full money back and they should pay return shipping!
The T520 has a discrete fan: 04W0439/04W1578/04W1579 (also works with integrated GPU)
or an integrated one: 04W0440/04W1580/04W1581
T520 integrated fans look like this: http://www.ebay.com/itm/201050818091
T520 discrete fans look like this: http://www.ebay.com/itm/252853056806
The W520 has a 55W fan: 04W0437/04W1574/04W1575
or a 45W fan: 04W0438/04W1576/04W1577
(both might also fit in a T520)
W520 fans look like this: http://www.ebay.com/itm/252853565994
It would appear that there are two exclusive heatsink designs for the 15.6" T/W series that are NOT compatible due to differences in the screw positions of the heatsinks, which may suggest further differences in the laptops' structure frames. The difference is illustrated in the T520 HMM and applies to all T510,T520,T530,W510,W520,W530.
Models compatible with the longitudinally wide base heatsinks:
T510 integrated & dedicated
T520 integrated & dedicated
T530 integrated
Models compatible with the latitudinally long base heatsinks:
W510
W520
W530
T530 dedicated
I don't have a T520 anymore so I can't inspect the physical parts of this laptop's structure frame that prevent installing heatsinks of one type in another. But it would seem the best heatsink you can fit into your T520 w/ integrated is the T520 dedicated heatsink with a thicker CPU heatpipe and two exhaust vents.
You may be bottlenecked with the T520. You may want to look into getting a dedicated gfx T530 or workstation W530 that can take the strongest Ivy Bridge CPUs and have access to the strongest heatsinks and do your OCing from there. Or get a desktop.
T530 integrated
W510
W520
W530
T530 dedicated
P71 X330 T60 et al
Thanks for this. I am looking to do the same T520 i5 to i7, only without overclocking.
Thinkpads: X395, X301, X230, W530, W701 "Astra"
Dell: Precision 5520 Xeon "LucieX"
@TPFanatic - I'm also looking at the HSF's for T/W52/30's with dGPU for the purposes of CPU upgrade.
Do I understand you to say that the W510, W520 and W530 dGPU HSF's can be exchanged with each other?
I don't belive the T530 dGPU would be compatible with those two. See that link and my pics there. The shape of the triangular GPU heatsink, differs.
T520 Discrete Graphics No Longer Work
by halitics » Sat Dec 16, 2023 10:34 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 6 Replies
- 1910 Views
Sun Dec 17, 2023 12:52 pm
X230 - what SSD will best fit in the WWAN slot?
by br1anstorm » Tue Nov 14, 2023 3:59 pm » in ThinkPad X230-X280 / X390 Series - 15 Replies
- 6235 Views
Last post by br1anstorm
Wed Nov 15, 2023 6:17 pm
Can a T43 15" mobo fit into a 14.1" chasis?
by Gonzaleitor » Wed Feb 07, 2024 4:46 pm » in ThinkPad T40/T41/T42/T43 Series - 3 Replies
- 759 Views
Last post by Gonzaleitor
Wed Feb 07, 2024 7:01 pm
Can I replace my T440p stock fan with a Noctua fan?
by cultOfThinkpad » Wed Jan 10, 2024 2:41 pm » in ThinkPad T430-T490 / T530-T590 Series - 4 Replies
- 1726 Views
Last post by keithsketchley
Mon Feb 26, 2024 10:04 am
Users browsing this forum: No registered users and 48 guests
