[T410i] Add Bluetooth module without BDC Socket
jkhsjdhjs
#1 Post by jkhsjdhjs » Tue Oct 03, 2017 3:39 pm
Hey,
I want to add an internal bluetooth module to my T410i, cause it doesn't have a BDC nor (apparently) a socket where a BDC could be installed:
https://i.imgur.com/VMbHzkd.jpg
So the only choice I have left is to replace the internal WiFi Module (FRU 60Y3231) with one that supports WiFi and Bluetooth.
I already tried installing the Mini PCIe WiFi + Bluetooth Module from a R61i in the T410i (slot under the mainboard), but on boot it said: "1802: Unauthorized network card is plugged in".
That's why I'm asking here now, cause I don't want to buy a module and notice later that it's not compatible, not authorized or whatsoever.
Do you know if it is possible to install a Bluetooth + WiFi module (ideally BT 4.0)? Or do I have a BDC socket on my T410i (in this case please tell me where I can find it)?
Thanks in advance!
Best Regards,
jkhsjdhjs
Re: [T410i] Add Bluetooth module without BDC Socket
#2 Post by RealBlackStuff » Tue Oct 03, 2017 3:54 pm
Get the illustrated manual (HMM link at the top of this page).
BT is mounted on the underside of the keyboard bezel.
Instructions in HMM.
jkhsjdhjs
#3 Post by jkhsjdhjs » Tue Oct 03, 2017 4:56 pm
Ahh, ok, thank you!
So the socket I marked in the following picture is the bdc socket?
https://i.imgur.com/6D4hexs.jpg
And according to this post I then should be able to install a BT 4.0 module in it, right?
WARNING: your pictures are WAY too big! Tags removed.
Please read the Forum Rules, especially Section 5. viewtopic.php?f=16&t=14339
MikalE
#4 Post by MikalE » Tue Oct 03, 2017 5:40 pm
I installed a W530 BT card in my T520. It came with a pigtail for other applications that was removeable for the T520. I would imagine the T510 will be the same, though I have not opened either of my T510's to look.
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
T520 i7 4242-4UU(CTO)
T520: i7-2760QM(2.40GHz),16GB, 500GB SSD/500GB 7200 Drive, 1600x900, 1GB NVIDIA, DVDRW, Smartcard, media card, FPR, Win7 Pro64, whitelist BIOS, N 6300 AGN, German KB, BT 4.0.
jkhsjdhjs
#5 Post by jkhsjdhjs » Tue Oct 10, 2017 6:18 pm
I was able to install a BT 4.0 BDC with the FRU 60Y3303 into my T410i and it works just fine!
Thanks to all of you!
