I went on vacation and came back to a dead T400. No lights, no power, nothing. Tried numerous resets and power drains to clear things out. Still nothing. I did replace the motherboard and had things working for a day or so, but my LCD was also dead. I noticed the new motherboard had a really old BIOS on it, so I upgraded which went just fine. System rebooted, finished the flash and turned off. I turned it back on and went into the settings to reset a few things and turn some things off. I saved those changes and now it doesn’t appear to boot up. The cpu fan will spin a few times, but nothing beyond that. I can take the memory out and get the usual beep sequence for that.
I have also replaced the LCD, the LED board and LCD cable, as there were no lights before I changed the motherboard or after. With the new LCD in place along with the LED board, nothing. Although this evening, I noticed that the LED for the power was on very faintly when I powered up. Still not booting.
Does anyone have any ideas as to what might be going on? I have never seen something like this before with as many ThinkPads as I’ve owned and worked on in the past. Is there another reset of some sort I need to try? I’m about ready to throw in the towel and sell off this thing for parts, but want to see if anyone has ideas I could try.
Thanks in advance!
Matt
Weird problem with T400
Current Systems: T470p, T440p & X240
Previous System: T400 (2764-CTO) - needs troubleshooting / work
Re: Weird problem with T400
TAKE OUT EVERYTHING!!! Basically, put in a known good piece of memory and a monitor over VGA. No battery, wifi/wwan, ssd/ etc. If it boots then, put pieces in one at a time to see if it will boot.
Took out everything I could, used known good pieces (ram and monitor) and still nothing. I’m stumped here, after replacing everything.
Does anyone remember if there is a process to force a BIOS flash reboot from this state? I seem to remember some kind of process where booting from a floppy could possibly flash to a back level BIOS for recovery.
Aside from that, anyone need a parts machine potentially? New LCD included.
T400 Not booting, lights flickering
by hellfire103 » Wed Jan 24, 2024 6:18 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 2 Replies
- 1138 Views
Last post by Gonzaleitor
Sat Jan 27, 2024 6:54 pm
Keyboard stickers for ThinkPad T400/T410/T420 and T500/T510/T520 Series
by PowerPC » Fri Feb 09, 2024 2:52 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 1 Replies
- 590 Views
Fri Feb 09, 2024 4:14 pm
Differences between a T400 and a T500/W500
by bessiebell » Thu Feb 15, 2024 1:29 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 1 Replies
- 462 Views
Thu Feb 15, 2024 1:34 am
256GB M.2 NVME work in a T400?
by RealBlackStuff » Fri Apr 05, 2024 12:13 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 2 Replies
- 166 Views
Fri Apr 05, 2024 10:52 pm
Users browsing this forum: No registered users and 36 guests
