T420 ESATA and Dock question
When docked in the Mini Dock does the Dock's ESATA w/o USB disable the laptop's built in ESATA w/ USB (T420) or ESATA w/o USB (T410) port?
Re: T420 ESATA and Dock question
No.
Powered USB and 3.5" Drive question
Is the powered (yellow) USB port on the Thinkpad powerful enough for a 3.5" drive? I would use the split cable with separate ESATA Data and Power plugs. Data into the ESATA port on either laptop or the dock, and Power into the Laptop's yellow USB.
What does the voltage on USB standard is? The powered eSATA is thus based on USB contacts with different contacts for eSATA and this means 5V only. 3.5" HD drives requires both 5V and 12V. Stick to 2.5" boxes or external power the 3.5" drive with required voltages. Yellow USB on thinkpads is powered optionally set in bios when computer is off or in standby.
Cheers, thinkpadcollection
All the ports can be set to "Always On" with power, but the Yellow USB port can be used for charging phones faster than normal USB.
T440p + Ultra Dock, but dock video out (HDMI) not working
by Arf the Lab » Sat Nov 04, 2023 6:58 pm » in ThinkPad T430-T490 / T530-T590 Series - 6 Replies
- 4197 Views
Mon Nov 06, 2023 1:39 am
X1 Carbon G6 8550U/ UHD 620 dock question
by ObligedTester » Mon Nov 06, 2023 3:16 pm » in ThinkPad X1 / X1-Carbon / X1-Extreme and later Series - 1 Replies
- 2033 Views
Tue Nov 07, 2023 7:05 am
T420 - Quad Core CPU and BIOS upgrade (or downgrade)
by ojciec » Fri Dec 15, 2023 4:49 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 3 Replies
- 5750 Views
Mon Dec 18, 2023 12:04 am
Keyboard stickers for ThinkPad T400/T410/T420 and T500/T510/T520 Series
by PowerPC » Fri Feb 09, 2024 2:52 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 1 Replies
- 391 Views
Fri Feb 09, 2024 4:14 pm
