I would love to make my thinkpad more future-proof, so I am looking for USB-C options and I found this PCI-E usb-c adapter:
[url] https://www.amazon.com/IO-Crest-PCI-Exp ... B01L83UJE4 [url]
Will it work? If not, will there be in the future some option to get usb-C working in thinkpad t420/t430?
Dave.
USB-C in t420/t430
Re: USB-C in t420/t430
That could possibly work, but the biggest issue is getting the USB-C port to the side of the machine. You'd have to modify stuff and try to find a way to mount the female end in the side to keep it anchored while finding safe routing for the cable. They make some pretty thin USB-C cables but if they have 'extension' cables that are in that 5-10cm range and where to put it, so you wouldn't be causing a space conflict.
It's definitely a possible, with a hacked bios to remove the whitelists for what's allowed to be in those mpci-e slots. The Asmedia USB3 controllers are quite well regarded as far as I know.
If you proceed with this, let us know and maybe post a walkthrough as I'm sure others would be quite interested in this mod. I'd be really interested in it, to be honest, but I just don't have the time to be hacking up my laptop at the moment.
T61 14.1 WXGA+ 220nit, T9300, Owl blade fan cooler, 8GB PC2-6400, 2010 revised NVS140M, Samsung 840Pro 240GB, AR9390 N, BT4.1, NMB keyboard, T400 palm-rest, 33++ battery.
T420s 14.0 HD+, i7-2460M, 16GB PC3L-12800, NVS4200M, Samsung 850Pro 512GB, Intel 7260AC, BT4.1, Chicony KB, 81+ battery
Just a few thoughts
* While you may be able to add USB-c connectivity to your thinkpad, it'd still be bottlenecked by the limitation of pcie speed. PCIe 2.0 caps out at 5 gbps.
* Another possibility, although slightly unwieldly, is to go for a expresscard based solution. The EXP GDC is often used to connect a desktop graphics card to laptops through the expresscard slot, but you could just as easily use it to connect an expansion card. Something like https://www.startech.com/Cards-Adapters ... PEXUSB312C might be an option, giving you usb c slots
Depending on whether you use your CD/DVD drive, you could remove it and replace it with a modified hard drive adapter fitted with a USB c hub and run the wire over from that adapter card. As long as you find the right hub, you'd be set. Could 3d print any necessary mounting parts if you needed something to hold the hub in place.
You could even have a few USB ports not exposed to the outside of the casing for things like Bluetooth adapters, Logitech Unifying receivers, etc.
I think I know what my next project may be!
Some call me...Tim.
Present: 13" 2015 MBP
Past: T420 || T500 || X61T || X60T || R50 || X30 || T30 || A31p || 3xx || 600E || Intellistation Z Pro
- 1 Replies
- 320 Views
Last post by jronald
Mon Mar 11, 2024 9:37 am
T430 Thinklight and Integrated Camera not working
by wurmhol3 » Tue Oct 24, 2023 10:58 am » in ThinkPad T430-T490 / T530-T590 Series - 2 Replies
- 2906 Views
Fri Oct 27, 2023 7:12 am
T430 eGPU problems (windows)
by Blackbeak2 » Sat Nov 04, 2023 6:43 am » in ThinkPad T430-T490 / T530-T590 Series - 1 Replies
- 2248 Views
Last post by SAIYAN48
Sat Nov 04, 2023 1:33 pm
ThinkPad T430 - white screen on boot-up
by br1anstorm » Sun Nov 12, 2023 5:35 pm » in ThinkPad T430-T490 / T530-T590 Series - 15 Replies
- 3687 Views
Last post by br1anstorm
Sat Jan 13, 2024 1:47 pm
