Does anyone have any experience with installing Windows XP x64 Edition on a T520? If so, did you have any trouble? Were there any drivers you couldn't install? And finally, how did it run?
I have a T520 that I'd like to install XP on and still be able to use the full 8GB of RAM. (Yes, I know XP is old and no longer supported and the x64 edition has some weird quirks with some software, but I just want to know if it can be done)
Windows XP x64 on T520
Re: Windows XP x64 on T520
Yes it can be done but driver support will be lacking at best.
I tried it on a W520. It actually had decent driver support but it took some searching to find drivers. Nvidia had a compatable driver but it wasn't nearly as good as the Optimus driver supplied by Lenovo for Windows 7. The main issue was that it didn't handle the i7 multithreading very well. Most of the processing was done on one core and the others were idle. In Windows 7 the processing was evenly distributed among the cores. I haven't found a Thinkpad that really works well for Xp x64. The two most promising ones, the W520 and W701 didn't work out. They both came out after Xp x64 and they both worked with it but not nearly as well as Windows 7 or Ubuntu. Driver support was a bit better for the W520 but that might just be that I looked harder and longer for the drivers. After one failure, I wasn't going to pursue another one very far.
I've got a T580, 2 W500s, a W520, an X201T, an X220T, an 3 X61Ts, a 15" T60, a 14" T60P, a 15" UXGA T60P, a 15" T42p a W701, and my first Thinkpad, a 770X.
Well if that's the case, it sounds like it's not worth the trouble. Ah well, I'll just keep Windows 7. Thanks for the info!
Multi OS T520
by shaftalignment » Tue Dec 12, 2023 4:08 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 3 Replies
- 3256 Views
Last post by shaftalignment
Thu Dec 14, 2023 9:02 am
T520 Discrete Graphics No Longer Work
by halitics » Sat Dec 16, 2023 10:34 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 6 Replies
- 1781 Views
Sun Dec 17, 2023 12:52 pm
Keyboard stickers for ThinkPad T400/T410/T420 and T500/T510/T520 Series
by PowerPC » Fri Feb 09, 2024 2:52 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 1 Replies
- 590 Views
Fri Feb 09, 2024 4:14 pm
- 3 Replies
- 680 Views
Fri Mar 29, 2024 11:27 pm
Users browsing this forum: Bing [Bot] and 35 guests
